I have an antenna set up for T5, but a while ago, the Miracle Channel moved to AMC-4. I use an old Star Choice (36" elliptical) dish/LNBF which works adequately. After looking at the specs and finding out that the dish was set up for 4 deg separation, I figured out the Star Choice switching and should be able to get AMC-4. Well......I managed to lock onto the Miracle channel for about a day with a very weak signal. After that, I was lucky to get any AMC-4 transponders.
I have acquired an offset fiberglass dish which measures 48" x 52" (approximately) I am not sure if the LNBF arms are the correct length or not.
My question(s):1- Will the mini-LNBF's that Glorystar shows on its website combined with the 4 deg offset dual bracket work with the offset dish I have work for T5 and AMC-4?
2:-Where can I find a formula to calculate the focal point and lengths of the arms? There is a bump at the approximate center of the antenna which I assume is the focal point. There is no brand name on the unit but it is commercial quality with a very strong, galvanized bracket.
Hope someone can help!
DSR-920
10' Paraclipse BUD
Viewsat Lite
Small dish garden....
DSR-920
10' Paraclipse BUD
Viewsat Lite
