antenna grounding question
robertjp
161
5
Upstate NY
Is it true you should ground both the coax cable to a grounding block and a separate ground wire to the mast back to the block? Where would you attach it to the mast? Thanks
I always slide the ground wire between the mast and the antenna mast clamp.
OTA in Reno, Nevada
OTA antenna
