AMC6 and SBS6
n8mycbob
13
Columbus, Ohio (Valleyview)
I am thinking about parking an 80cm dish on SBS6 but I see that AMC6 is just 2 degrees away. Is it possible to strap another lnb off to the side to get it?
Bob
80cm fortec parked on 10R
Lifetime Ultra
Directv
OTA HD
No chance the satellites would have to be at LEAST 4 deg. apart or the LNB's cant be placed close enough to each other!
I wouldn't waste an entire dish on amc6 that's why I asked about the extra lnb. I like feeds though. I guess when I get a mortorized ku system I can slide on over and check it out. I do however want ONN full time on one of my tv's
4 degrees is pushing it
Tim I don’t know if you’ve seen the StarChoice quad LNB. With the 2 satellites being 3.8 degrees apart (107.3 & 111.1) the LNB “eye” looks “squished”
Can you get 2 KU satellites 4 degrees apart? Yes…the old rectangle LNB’s on DirecPC dishes work real good :D
and they wouldnt be side by side...thats more of 7 or 8 degrees
the LNB eye needs to be right next to each other...I have a DBS LNB next to the KU band (both look like the old DirecTV rectangle LNB’s and when I’m on 74 (SBS6) I can get 82 (Nimiq2) with semi decent quality.
Is it possible to subscribe to encrypted stations?
How much of a "Southern View" do I need?
