Am21 and HS17
minimonster17
FL
Hello. I am a new poster, but longtime lurker. I recently purchased a new in box Am21 that had never been used on eBay. How do I correctly hook this up to an HS17 server?
I assume I will need to retain the EPS17 to supply power to the HS17, and use the separate power cord included with the Am21 to power it.
Am I correct in my thinking? Can I use the usb cable included with the Am21 to connect it to the HS17, or do I need a different usb cable to bridge the OTA device to the server? Thank you in advance for your assistance.
You need to use a separate power cord to plug it in. The one connected to it is for older receivers like the Hx2x where you would daisy chain the power cords
You can use the same USB cable, that goes directly to the HS17.
Reactions: lordodogg
New Genie Menus Coming in July
