I'm not sure if the USB port went out on my HR54 or what's going on here.
I have an AM21 that has good incoming signal to it. I have disconnected the cable, ran the scan on my TV and it finds every local channel for my area. Plugged it back into the AM21, go through the initial setup and it won't find anything, and I can't go in and see the signal strength on it. The TV reports good signal on its OTA when the cable is plugged into the TV.
I swapped out the AM21 with a spare AM21, both do the same thing. I tried to swap out the USB cable as well, nothing. I cant get this HR54 to find channels. It goes through the whole process only to find zero channels and the HR 54 diables the two antenna ports.
I am not sure why it wont work. Any suggestions.
Yes I have rebooted the HR54 both by RBR and pulling the power, many times.
