The Sling adapter takes over TV2 and only works with 722s, you cannot view TV2 locally and with the adapter simultaneously.Does the sling "steal" TV1 when in use? or can someone watch TV1 in HD, while someone else watches different HD via Sling?
And Sling only works for the 722? (so us folks with 622s don't have this option?)
thanks!
the bottom line is that H+J is an $11/month upgrade to get TV2 to be HD vs. (SD with a 622/722)... that seems like a big jump.
A Slingbox can work with the 622 (or any receiver) and can use either TV1 or TV2 depending on which outputs you have it connected to. If you want HD it will need to be connected to TV1. The local TV and Slingbox can be used simultaneously, but will have to view the same show, and you may have "dueling remotes" between the local and remote user.
