Clckwrk,
I looked over all of your settings and I cannot find anything incorrect. However, there might be a small procedural complication here due to the AZBox operation, so try the following by accessing the following menu tree on your AZBox:
SETTINGS ? TV CHANNEL ? TUNER A DVB-S ? SAT/TP EDIT ? SATELLITE NAME (scroll to 83.0 W AMC 9) ? TP FREQUENCY (scroll to 11735 MHz).
Then, ensure that the SYMBOL RATE = 4440 KS/s, POLARIZATION = horizontal, MODULATION = DVB-S/QPSK, FEC = 3/4 and PILOT = 0.
Wait 10-20 seconds for the tuner to stabilize and present you with a SIGNAL STRENGTH reading (the top blue bar graph).
From here on out, monitor the SIGNAL QUALITY (the lower orange bar graph) for any positive indication. If you can take the AZBox receiver and a portable TV out to the dish so you can monitor this SIGNAL QUALITY reading, I would highly recommend that you do so. If you really cannot do that, it is going to be a longer process, but you will just have to do what you can. If you have to incorporate your "screaming" meter, do so.
Start with the dish elevation and azimuth set as close to the settings you found from dish pointer. Ensure that you polarize the LNBF to approximately 5.3° (twist it to the west). Satellite 83.0°W is west of your location, so you must rotate the LNBF in the direction of the satellite.
Think of the satellite as a [ + ] sign riding on a rainbow and the rainbow is the Clarke Belt over the equator. The vertical bar represents the vertical polarity signal and the horizontal bar represents the horizontal polarity signal (obviously). If the satellite is due south of you, the vertical bar is straight up (perpendicular to the surface of the earth) and the horizontal bar is parallel or tangent to the surface of the earth. Every satellite is aligned this way in reference to the surface of the earth. But, since 83.0°W is not due south of where you are, the [ + ] sign is going to appear tilted from your vantage point. The further west of you a satellite is, the more the upper portion of the vertical bar leans to the west and the more the west side of the horizontal bar leans downward, too. Inside the LNBF there are pickup probes that form a [ + ] and must be aligned with the satellite [ + ] polarization. So as you pick satellites further west, you have to rotate the LNBF west to maintain the alignment of both.
You don't have to be extremely accurate with the degree value that you rotate the LNBF. It is not as sensitive to this orientation as you might suspect. But, you should attempt to be close and then when you get a signal, you can fine tune it for an optimum signal.
Next, manually rotate the dish on the mast east or west just a tick. If you are using the audible meter, listen for a HOT (strong) signal, then switch over to your AZBox and check the indication on your SIGNAL QUALITY meter. If you hit the correct satellite and TP, the meter should show you a valid response. If not, pan the dish a little farther till the next signal is found and recheck it. You'll have to keep doing so until you have finally dialed into the correct satellite. Just remember, that if you are using the SIGNAL QUALITY meter on the AZBox, make sure that you allow 10-20 seconds for the tuner to LOCK properly. Other receivers and their tuners are more responsive for this (quicker to lock), so with the AZBox you will have to use more patience. 10 - 20 seconds is probably an extreme measure, but just try to give it that time at first, till you get accustomed to the speed of your tuner.
The major problem is learning how to make the most finite of adjustments and giving the tuner the time to lock. All receivers require a measure of patience in this regard, but the AZBox may be slower than you anticipated. It's not bad to lock signal once the system is setup, but searching for signals for the first time is a little different, so just keep this in mind.
Now, once you have panned the dish east and west across the general location where the sat you are looking for should be, if you don't lock on to the proper signal, you have to adjust the elevation or your dish and start the process all over again. Mark or record where the elevation was and try it 1° higher or lower. No luck there, then try 2° higher or lower and do it all over again. If you get to 5° or more off (higher or lower in elevation) and haven't achieved a lock yet, then you are either panning the dish way too fast or there is something wrong.
It is not difficult and if you utilize the angles that you found from dish pointer, you should almost get it during the first few minutes of trying as those angles are quite accurate. Since all the information / data that you have supplied us appears to be spot on to me, I can only assume that the problem is with your panning procedure. But, that doesn't mean that there isn't something else wrong that I or others have missed.
Of course, I have to recite the #1 rule. Did you double check the plumbness of the mast? The mast must absolutely be perfectly vertical or none of the angles from dish pointer will be valid. Bare in mind that this is an often overlooked point by many folks, so don't feel badly if you made the same mistake. It is not uncommon, so ensure that you double and triple check this. You must be SPOT ON with the plumb of the mast, it is so extremely critical that you must ensure that it is perfect.
Looking forward to hearing back from you and wishing you good luck.
RADAR
