My 12 ft. dish has a plastic base that the big "thimble" shaped feed-horn cover attaches to.
Then the scaler assembly is screwed onto that. The support arms for the assembly are attached to the plastic base for the cover, and I am finding it is a POS and I can not keep the signal centered..I have a laser centering device and the plastic base is just not the right setup to keep that signal centered right.
I would imagine that it should be OK to just eliminate that feed-horn cover assembly all together and support the scaler directly to the supports...Is that a good idea??? I took the feed-horn cover off a Hughes Internet feed-horn assembly and ran 7 years with-out it and never had any problems..Is it OK to have my dual orthomode feed-horn and high-end LNB's (all 4 PLL) exposed to the elements ??
I also heard that by removing the hard plastic cap on the front end of the feed-horn and replacing it with a Styrofoam coffee cup bottom (cut to fit) will give you a couple more db's.. can anyone verify that???
I'm in the jungle, no snow and ice, but lots of rain, and I am hoping I can just eliminate that big ugly cover, and get things centered up properly.I would appreciate any advice or ideas anyone may have, thanks, HB
