The DSR200c will register Signal of 70 - 85% when connected to a LNBF that powers up, so that seem normal. The Signal Quality may spike occasionally, but the indicator bar will not turn green unless you are on a satellite.
- Perform a factory reset on the unit and activate temporarily in the Glorystar mode.
- Not sure exactly where you are in PA, so these coordinates should be close.
- Rotate the LNBF counter clockwise to a +18 degree setting.
- Aim the arm of the dish to a compass reading of 215 degrees and identify a landmark in the far distance (tree, telephone pole, chimney, etc.) that aligns with this compass reading.
- Set the dish elevation to approximately 40 degrees using the angle scale on the back of the dish.
- Select channel 901 and observe the Quality Reading as you SLOWLY sweep the dish 10 - 15 degrees on each side of the landmark. If the Signal Quality does not increase and the TV display programming, increase or decrease the elevation by one degree and slowly sweep either side of the landmark. You may have to repeat this movement many times and go 5-10 degrees above or below the starting elevation setting.
- Once you receive the Signal Quality reading and a picture on 901(transponder frequency 12152, strongest TP on Galaxy 19) exit the Signal meter screen and enter the menu.
- Perform a factory reset and activate in the Advanced All Satellite mode.
- Enter the Channel search menu and verify Galaxy 19-KU is selected and the LO Frequency is set to 10750, then perform a Blind Scan Search of FTA channels using 6 or 8MHz steps.
This should scan all of the free channels available on Galaxy19. Once you feel comfortable playiong with the fixed dish, add the motor into the mix!
