Adding new VIP 222k
TMaC750
Central MN
I have installed a few dish systems but I am at a wiring stand still. Here is what I have: VIP 722 that is wired for 2 TV's I bought a 222 that I want to add. There is only one wire coming from the dish so how do I hook up the 222?
You need to run a second from the LNB on the dish to the location where the 222 will be. Use the separator, run check switch, call and activate.
The original installer had 2 receivers on the same cable from the dish (1000.2). I already have 2 runs to the dish so hooking up another one is not a problem. I can send pictures if needed.
Each receiver will need its own cable from the LNB. Jimmerinwi has the correct setup for you.
722k hd dvr
These are a few of my least favorite things (Hopper Issues)
