Hello, I currently have a 722 in my living room, (and a 322 in one bedroom) I want to run the 722 in single mode and get a 3rd SD single tuner receiver
to use on the tv that currently is hooked up to TV2 on the 722. If I purchase a used receiver either a 301 or a 311 will I have any problems activating it? I read on the forum that some receivers have smart cards and others have them built in, my LNB says it is a DPP twin.
Since I will not have the cable going to "TV2" from the 722 can I remove the splitter/diplexer from the back of the 722 and use the single cable coming in to the 722 with the splitter/diplexer to feed both of the sat. inputs? currently there is 1 cable coming in going to a diplexer than 1 cable goes to sat in, the other cable goes to a second diplexer in which 1 cable goes to sat in 2 and the other goes to "TV2".
Will I need to run a seperate cable from the dish to the new receiver?
If a used receiver is not a good idea any suggestions on where to purchase a new or reconditioned one fairly cheap?
