actuator trouble ?
digitalmarch
12
in my basement
hi
i have a motek 36 "
the actuator only opens 7 cm and then stops
the actuator closes at digits 130 on my v box (vbox 6)
so the dish dont move very far
what are the causes of that ?
Did it work previously? Is there an error code displayed?
If it's a new, are there limit switches in the actuator? Adjusted?
Can you connect a 12v battery to it, and make it extend further?
A bit more info would be helpful.
i got an err2 message on the v box
the actuator is brand new havent tried the battery on it
Er2 is no pulse, so I bet it is the upper limit sw in the actuator. If you were to use a battery to run the jack out, and it stops at the same extension, the upper limit switch of the actuator is set improperly. Adjust as necessary.
Uniden UST 7700 at Satellite Selector - manual
C-Band Dish Signal Angles
