Only if you ran coax cable from the first receiver to the second TV. This would be a SD only solution and any HD programs, although they can been seen, they will only be in analog SD, therefore the picture quality will deteriorate the longer the cable run. The only other thing which can be done, is if you get another 622 or 722 receiver. Then you can hook up an external hard drive and transfer recorded content to the hard drive and bring the hard drive to the second receiver. Although, I am not sure if this feature is activated currently to allow you to hook the hard drive up to two different receivers at different times. Maybe someone more knowledgeable can chime in here.
