TP is fine..
Signal at 11874 H 22000 is Strength 77 / Quality 98 (maximum on this BEC 6600+ receiver)
It has nothing to do with Quality.. (not Quality of the TP anyhow)
All the other channels are fine on this TP...
The problem is.. and you can check yourself for this next time (if have a machine that shows you PID values.. otherwise some other machines like digiwave/kusat, etc - you have to dump the receiver..and then PID values appear...
In any case... the problem is - the channel is gone (for now.. currently anyhow) - it became a Data channel with NoPIDs... (if you can - press Info while on it - it will show you - 0 0 0 (vpid apid pcr)
So basically - only EPG name is uplinked currently .. with no pids.. (and often those are just gone.. and like this forever.. unless provider stops uplinking the EPG name as well .. or unless they fix it or reuplink the content and pids on it.., etc)
later
