The DPP44 is powered by the power inserter on port 1 which feeds a 301 upstairs.
Port 2 feeds the 625 downstairs.
Port 3 feeds the 301 downstairs.
I'm working with Ports 2 and 3 going downstairs.
I did some testing as I installed all this.
And I tried all this testing with and without the Attenuator connected to the modulated output from the 625. Made no difference.
I tested each Diplexor individually with only one signal.
1. Port 3 output to SAT input, IN/OUT to 301 to TV( via S-video )
2. 625 Modulated output( various channels air and cable ) to U/V ANT input, IN/OUT to TV RF input.
That all worked fine.
Then I tested both Diplexors together with only one signal.
1. Port 3 output to SAT of first Diplexor, IN/OUT to IN/OUT of second Diplexor, SAT of second Diplexor to 301 to TV( Via S-Video ).
2. 625 Modulated output( various channels air and cable ) to U/V ANT of first Diplexor, IN/OUT to IN/OUT of second Diplexor, U/V ANT of second Diplexor to TV RF input.
Then I tested both Diplexors together with two signals in and one signal out.
1. Port 3 output to SAT of first Diplexor, 625 Modulated output( various channels air and cable ) to U/V ANT of first Diplexor, IN/OUT to IN/OUT of second Diplexor, SAT of second Diplexor to 301 to TV( Via S-Video ).
2. Port 3 output to SAT of first Diplexor, 625 Modulated output( various channels air and cable ) to U/V ANT of first Diplexor, IN/OUT to IN/OUT of second Diplexor, U/V ANT of second Diplexor to RF input of TV.
So I hooked it all up with two signals into the first Diplexor and two signals out of the second Diplexor.
The U/V ANT output from the second Diplexor to the RF input of the TV works fine.
The SAT output from the second Diplexor to the 301 will not work unless I unhook the RF input to the TV. It is stuck trying to find a satelite signal and makes a BZT, BZT, BZT sound.
I even tried sending the U/V ANT output from the second Diplexor to the TV Antenna/Cable input of the 301 and then the TV Set out of the 301 to the TV RF Input. Got a really bad snowy picture and the SAT input to the 301 was stuck trying to find a satelite signal but I didn't get the BZT sound.
I'm lost.
My next try, when I get a long enough cable, will be a coax direct from the 625 Modulated output to the TV RF input. It's just on the other side of the wall thru a doorway so I can test it before drilling a hole in the wall.
Thanks for the help and suggestions.
Sorry to drag on so long but I'm trying to cover all bases and give as much information as possible.
