I realize it may be bad timing to ask this the night before the SuperBowl, but things happen when they do.
I also presume the answer to my question below is probably "no" but it can't hurt to ask. Is there any way to undelete programs deleted in error from a Dish DVR ViP 622?
My principal "ouch" is about how even if you "protect" a program it only puts it lower in the "overwrite" que. It does NOT protect from having it wiped if some command appears to sieze the space. Which I had to learn the hard way.
My overall story is an even bigger ouch. After losing the feed intermittently (for whatever reason) it gave me 30 instances of Friday's Bill Maher in 2 minute increments. Rather than delete each instance separately, I tried the "group" command thinking it would show ONLY the group with the same title, after which it would be safe to "select all" and then "delete."
Wrong-O. Big time!
Beneath that clump of 30 Bill Maher slices, there was the REST of my entire DVR menu, including several "protected" items which <silly me> I thought would never be wiped without a second command that permitted it to do so. Turns out instead, when I said "delete all" I was doing so literally, without nary an "are you sure?" screen to make me think twice before wiping the WHOLE hd. Now I have NOTHING left.
When things get this nuts, there is no choice except to accept and learn from it, unless you are willing to slit your wrists, which I am not over 9 months of saved and tagged TV shows. However, the incurable optimist in me still wants to think there might be a way to recover the deleted content before all of it is overwritten.
Wrong-O. Big time!
Am I hoping in vain?
