GEOSATpro A/V Cable for Micro HD STB
chc59
95
15
Dalton, Ohio
Looking to resurrect my Micro HD receiver to use with a composite video tv. Need the A/V output cable that I thought I had. (Maybe not. Always used with hdmi) A camcorder cable will not work because the 3.5mm plug is too short. The last ring, the ground, is longer. Where can I get one? Google is usually your friend but no luck there.
Attached is the pinout diagram.
Thanks,
Joe
  • microHD AV Plug.pdf
A cable with looong 3,5mm jack is also used by SAB receivers; though with left and right swapped obviously, in the pin-out.
See https://www.satellites.co.uk/forums...llite-tv-receiver.170776/page-12#post-1009933
(and also the links in that link).
I would think a SAB dealer should have them, or maybe you can also order in the Netherlands (SAB Satellite head office, Rotterdam)?
(See post #230 in the above link; maybe there is a link to order one?)
I don't know how to find it in the USA, though
I myself found two such cables at fleemarkets; however with still another coloring/pinout of the cinch plugs (see the link above). Sorry, both in use now...
Greetz,
A33
