Matt... Are you certain that they're on 99c? After reading your post I checked mine and I have great (93+) signal on 99a and 99b, but 99c does not even show up when I toggle through all the sats. I went to channel 704 and there is guide info (upcoming:etc.) I'm beschmuggled as to why no 99c.As I understand it, the NFL ST SF channels are on 99c. I went ahead and did a signal test for this and I saw a lot of numbers pop up between 74-80. This is getting close to down near 70. Should I be concerned or no?
I read over on DBS that they will be on 99c. Hopefully my signal strengths do not go down.Matt... Are you certain that they're on 99c? After reading your post I checked mine and I have great (93+) signal on 99a and 99b, but 99c does not even show up when I toggle through all the sats. I went to channel 704 and there is guide info (upcoming:etc.) I'm beschmuggled as to why no 99c.
UPDATE: Googled more information-- Directv HD rec'vr will show 99a (for conus) and 99b (for spot beams) but the HD-DVR will show 99c (for conus) and 99s (for spot beams) ( thanks to bosco10021)
Now some of my numbers are in the 60's on 99c and 103c. Maybe thats because it rained 4 steadily all day? Gustav's remnants were raining down here in Chicago all day. If the numbers are in the 60's though, will that be good enough or no?
