8300 User Experience and Tips
wtped64
7
I just got my 8300 Monday and scheduled my first weeks worth or records.
So far I love this device. Having never had a Tivo, I hear that it isn't as good. Other than the :30 Skip feature on Tivo what things about its programming and scheduling aren't as good. Are there any advantages to the 8300 vs Tivo?
Anyone have short-cut, hidden features etc that they could share?
"Having HD is good-Having an HD DVR is even better!"
FROM DOUBLEDAZ on AVS FORUMS
SA 8300 HD Tips & Tricks
Okay, here goes! Much of this I edited, updated, and tested from the excellent SA8000HD posts by AVS Member 'vegggas'. Others I added from personal experience and still others are credited to original posters from our local forum with literary license taken by yours truly. Folks new to the SA8300HD should take the time to read the Guide to get a basic understanding of DVR operation, etc.
Link to vegggas' original SA8000HD DVR - Cox - SARA - Setup and Review Guide
Slow Motion Mode. While viewing a recorded program, press Play a second time to enter Slow Motion mode.
Frame Advance Mode. While viewing a recorded program, press Pause, the FF/REW buttons now become Frame Advance buttons. This is particularly useful when....well, you know when it's useful.
Fast Forward/Rewind. Pressing the FF or REW button starts the desired action. But did you know you can press them up to 3 times to increase the speed? If you press a button once and then press it again, the picture can lag behind the action or even freeze and result in going too far in either direction. However, if you press the button quickly, there is little or no picture delay and you minimize the chance of going to far.
Mimic Tivo Jump-Back.Tivo users have gotten used to the way it 'jumps back' a few seconds when you hit Play after fast forwarding. You can mimic this behavior by hitting the Replay button, the one with the curved arrow on it, instead of the Play button. This will bounce you back a few seconds and resume normal speed from there. So, when you see the show come back on, hit the Replay button and it should start playing near the fade-to-black between the last commercial and the program. Once you get the hang of it, it will become quite natural. (DravenStone)
One caveat. The next time you press FF, you will be given the "next" FF speed from the one you were previously using, rather than FF1. If you were using FF2, hit Jumpback, watch some of the show, and then hit FF, you will get FF3 instead of FF1. A better way might be to press Play and then immediately press Jumpback. (57U from HDTVoice)
Another way to mimic this action is by pressing the Pause button instead of the Play button to stop fast forwarding. This way, when you hit the rewind button to back up to the precise place to restart the program, it will remain paused instead of immediately starting to play again. I have found that this makes getting to the right starting place a lot easier. (gwsat)
FWIW, the FF speeds are 4X, 10X and 30X.
Disappearing Bar Graph. Hit the Exit button. If you are doing the frame advance/rewind trick, you can get rid of the bar graph by hitting the Exit button immediately after hitting the FF button. The bar will stay away until you're finished with the advance/rewind. (57U from HDTVoice)
Diagnostic Mode. There are two ways to enter the Diagnostic Mode:
Press and hold the Select button on the front of the unit until the Mail light starts to flash, then press the INFO button.
Press and hold the Pause button on the remote until the Mail light starts to flash (around 10-15 seconds), then press the Page Up (-) button.
Disappearing Diagnostic Window. Enter the Diagnostic Mode (see above item). While in this mode you can change the transparency of the screens by pressing the Select button on the front of the box. It goes from 100% opaque to about 50% opaque to about 5% opaque. You can then use the Page Up/Down button on the remote to cycle through screens. This is useful when changing channels, noting signal levels/PQ, or trying to see levels fluctuate as glitches occur.
Finding SARA Software Version. Enter Diagnostic Mode (see above item) and scroll through the screens until you find the one entitled "Software Versions". The version number will be in a format similar to 1.85.14.3.
Forced Reboot (without unplugging unit). On the front of the box, press and hold both the VOL+ and VOL- buttons, then press the INFO button.
Last Resort. If for some reason you can't get the STB to do what you want and you've rebooted it by unplugging it, etc., this is a "last resort" item - say just before taking the unit back, you can try reformatting the HDD.
The SA8000HD (and presummably the SA8300HD) has a fairly simple procedure to erase the drive (start clean). Note that this process will erase all scheduled programming and will cause the unit to reload all programming data from your cable provider. On the plus side, it will repair any fragmenting problems. (57U)
Press and hold PAUSE until Mail led is lit. Press PAGE down or (-),
and then press LIST three times. Turn box off. When turned back on,
formatting will begin.
Skip To End 1. Let's say you schedule the recording of a program and go out for dinner. When you get home, you begin watching the recorded program from the beginning while the rest is still recording. When the recording ends, you are 'kicked out' of your viewing. You then have to reselect the program from the list of recorded programs, but the only option is to start viewing from the beginning again. You can FF through to the point where you left off, but if it's a 2-hour program and you were 10 minutes from the end, FF can take some time. However, at this point, if you press Stop you will be given more options (Restart, Archive to VCR, Erase, Skip to End). If you choose Skip To End and then use REW, you can get back to the point where you left off a lot quicker. Remember that pressing the REW button 3 times increases the rewind speed.
Skip To End 2. Another option. If you happen to be watching the clock and you know the recording is about to end, simply press Pause and wait for the recording to end. Once the clock ticks, you can press Play and view from the point where you paused. NOTE: You *might* have to be inside the buffer for this to work though. (DravenStone)
Skip To End 3 - Skip To Beginning Workaround. Another option. Stop the current recording and save it (usually during a commercial). Then start a "new" recording to finish the program. You can then view the first part from the beginning and then view the second part, either in progress or from the beginning after it finishes. While it is annoying to divide the recording into segments, at least you can easily skip to the beginning without rewinding, certainly a useful feature for time-shifting. (Northern Lights)
Checking Status Of Current Recording. You can use PIP to check on the status of a program that is currently being recorded. The recording program will be displayed in the PIP window. If you are watching a program that is being recorded while recording a second program, the second program will be displayed in the PIP window.
Program In Progress Recording Bug Workaround. Most times you can start recording a program you are watching by simply pressing the Record button, editing the settings, and then Accepting them. However, there appears to be a problem when the program you are watching started before midnight and it is after midnight when you want to start the recording. Simply put, nothing happens. The recording doesn't start and the program does not show up in the LIST. We believe there might be a workaround. (DMorgan486)
The easiest way to avoid this bug is to simply record the program even if you are going to watch it. This requires you to FF to the point where you want to start watching from, and this can take some time, but it's better than missing the end of the program.
Another way is to press the Record button and edit the Start time to start the recording from the current time. NOTE: This has not yet been tested.
Here is an explanation of just what happens and another way to avoid being kicked out to live. The main tuner is using the buffer AND being recorded. As long as you are viewing the buffer, you have 1 hour of timeshifting, independent of the recording. I frequently will have the main channel set to something I want to record that lasts 1 hour.Once it starts, I hit pause. At that point, I will hit LIST and switch over to the DVR channel, but the buffer will still be in progress. I can choose a half hour program, which usually lasts about 20 min, or an hour program that lasts about 40 min. At the end of my pre-recorded show, I will punch in the channel number where I paused, and begin viewing where I left off at the paused point. At the end of the program, it doesn't kick me out because it's in the buffer, UNLESS it needs to change the channel for dual recording. A single recording will happen in the background.
Program Distribution. The 8300HD has 2 tuners and 2 outputs that can ALL be used at the same time. The Archive To VCR option does not have to be used only with a VCR. You can connect another TV (or VCR) in another room to the output connections and then view a downconverted pre-recorded program using the Archive To VCR option. At the same time, you can view a different recorded program on the main TV. However, it doesn't stop there. You can still record two other programs at the same time. You could easily send a recorded show to another room for your spouse/kids to watch while you watch a recorded/live program on the main TV without the fear of blocking any other recordings.
NOTE 1: I have not tested this myself, but others have, including one who streams programs to a central PC for further distribution/remote control.
NOTE 2: The 8300HD technically has 4 tuners; 2 NTSC and 2 QAM. However, only 2 of these can be used at any one time. Therefore, for the purposes of this and the next tip, the number of tuners has been limited to 2.
It should be noted that the 8300HD can also be connected to one device via HDMI and to another device via Component at the same time. In fact, a local member has it connected through a Geffen 4x1 DVI swither, and a 45 foot DVI cable, to his Marantz VP12S3. While this is supposed to be way beyond DVI specs, it has worked flawlessly. This same 8300 is also connected via Component cables to a W-VHS deck for permanent archiving. (kloarizona)
Viewing A Third Program. No matter how many tuners the 8300HD has (2), there are times when they are simply not enough (how many are? ). Oftentimes, you will already be recording 2 programs and you want to watch (or even record) just one more. Well, you still can, but you will be limited to OTA or analog cable channels and SD resolution. There is nothing to keep you from hooking up an antenna to the ANT input on your TV and switching to that input to view a third program. There is also nothing to keep you from splitting your cable and running a second line to your TV to do the same thing. There is also nothing to keep you from running that second line to a VCR and then to your TV to view/record the third program. (DMorgan486)
Audio Out Using HDMI Connection. An HDMI>HDMI or HDMI>DVI connection will automatically select 2 channel stereo if your TV does not support Dolby Digital (DD). In order to restore DD audio out to your receiver, you need to change the automatic setting. Press the Settings button twice and scroll to Audio: Digital Out. Change the setting from HDMI to Dolby Digital. This will force DD audio to the HDMI, as well as the digital/optical audio outs.
Removing Bars On SD Channels. As the 8300 comes setup from the factory, you get side bars on non-HD channels and have to toggle zoom modes to get rid of them. However, this often loses much of the image. Therefore, you may want to add output formats to your settings so you can stretch SD channels with your TV to get rid of the bars and avoid uneven phosphor wear (burn-in). To do this, you have to go through the standard S-A setup routine to enable formats other than 1080i, the box comes with only 1080i enabled by default. You also have to set the General Settings to Pass-Through. Press the Settings button twice and scroll to Set:Picture Format, select Pass-Through.
With box OFF and TV on, press Info and Guide (on box) together, then follow directions on the screen to enable 480i and any others you want. Cox passes 720p (ABC, FOX, ESPN), 1080i (all other HD channels), 480i (SD channels), and 480p (music channels). You will probably not see a difference between 1080i and 720p, so only enabling the one your HDTV uses will minimize reformatting as you scan through channels. Note: The 480i/p Widescreen options allow the 8300 to stretch the image to fill the screen for SD channels. Do not enable them if you use your TV to stretch the image.
Display Format Summary.
Fixed - Displays all content at whatever resolution you selected, based on what you selected in the wizard. You force the output to a single output and the box scales to that input. Easily changed in the settings menu of the box.
Pass Through - Passes the input signal through to the output with no change, unless you disable certain resolutions. For example 480i in to 480i out, 480P in to 480P out, 1080i in to 1080i out, 720P in to 720P out. If you disable 720P, 720P in will go to 1080i out.
Auto HDMI/DVI - If you are using the HDMI port, you will see this option instead of the Pass Through option. Resolution is automatically formatted to the scan rate supported by the TV.
UpConvert 1 - All 480i and 480P signals get upconverted to 480P. All 720P and 1080i signals get upconverted to 1080i.
UpConvert 2 - All 480i and 480P signals get upconverted to 480P. All 720P and 1080i signals get converted to 720P.
Auto Shut-off Workaround. It appears that you can defeat the Auto Shut-off feature by setting the General Settings/Timer: Turn Off option. You can set the Timer: Wake-up option for 1 minute later to keep the unit on virtually 24/7. This can be especially useful if you have the 8300HD connected to a Replay TV or other devices that rely on the 8300HD being on for channel changing, etc.
V/H Resolution Information. If you are using the SA8300HD or the SA8000HD, with rev 1.87.xx SARA software, one of the diagnostic pages (pg 30) shows the MPEG decoder input vertical and horizontal resolutions from the cable company or their source as it hits the STB.
Potential Recording Conflicts. There have been reports that "old" scheduled recordings of programs that are no longer on might cause the 8300HD to get confused at some point. This can result in lost recordings or the inability to set up new recordings for the same timeslot. Here is a short explanation (edited) of the problem. YMMV.
quote:
While trying to record 2 shows at once last night, I couldn't get one of the channels to record at all. Instead, it was recording 1 program that I had scheduled and 1 I had not. When I tried to cancel the one I had not scheduled, the 'yes' button would not work. Also, this recording was not showing up in the recording list (King of Queens was recording, but it was not in the list).
After a few minutes of frustration, I reviewed my list of scheduled recordings to see if I could find a cause. There were a few still in the list for programs that were no longer on, such as Survivor. The schdeduled channel/time for that old recording matched the channel/time of the mystery program currently being recorded even though the program titles did not match.
So, it looks like the 8300HD scheduler got confused somehow and was applying the old scheduled recording channel/time even though the titles did not match in the guide. I did find a new "Survivor" recording in the list, but it was marked with a time of -59 minutes and clicking on it led to a black screen.
I eventually got it worked out (after missing 15 minutes of the show I wanted). The moral of the story is to clean out old scheduled recordings for shows that are no longer on. It looks like the 8300HD can get flaky if they are still in the list (even though they shouldn't affect new recordings).
PassPort Related Tips (May or may not work with SARA software):
Instant 15 Minute Jumps Forward or Back. You can Fast Forward or Rewind in up to 15 minute intervals simply by doing the following:
1) Press the FF or RW button (once, twice, or thrice, doesn't matter as long as you're in the FF or RW mode).
2) Press the Directional Button (the < or > buttons surrounding the Select Button) that corresponds to back ( < ) or forward ( > ), depending on if you want to rewind or jump ahead. Each press of the Directional Button will jump you forward or backward to the next 15 minute mark.
Some nice tips I did not know about. While not as polished as some of the older Dish PVR's (501/522) I had, the 8300 is far more stable then the 522 ever was AND records HD :).
Problem
Last night while watching/recording 24 I did get a notice that it was about to start recording MEDIUM on NBC, and I was recording but wanted to watch CSI on CBS at the same time. I changed the channel to CBS to watch CSI. For some reason I never recorded Medium and only 1 minute of CSI. Did my changing the tuner at a certain point do this?
M&C for Modem
Help me convince my condo board to allow dishes!!!!!!
