811 Lost Wing Satellite
try this:
Remove all satellite inputs from the back of the box . Do a switch check
Then reconnect only the 110/119 feed from the Sw34 (leave the 148 off the switch). Do a switch check. - should see SW34 and 100/119.
Add the 148 feed to the switch. -do a switch check.
I'm sure you've tried that, but just in case.
I'll give it a try. I assume having no satellite on the switch does a version of
a reset on it. I had only one receiver, 6000, and the one satellite, 148,
feeding the switch, but still had the signal seen as one from a 119 by dish pointing.
I'll try your approach using only one receiver, since I saw notes about
possible problems with 3 or more receivers on the SW34.
Will the Lack Of a dishwire stop u from buying a 921
A channel on how to use your DVR??
