timclark said:Seedoo
My point was to eliminate HDCP as the culprit, as they consider the component and DVI outputs to be "digital" and force the copy protection scheme on both outputs. I might be wrong on this bit I have seen posts that indicate it to be true.
So if you got picture on the component outputs then it may not be an HDCP issue.
I do have picture 1080i with componet. When was the software update. This worked with the DVI when I first installed and it has now been several months that it has not worked.
