76 CM Good to go?
Sorry about posting in the wrong area. Ice, you are even a bit further north than I am. Does it get clear reception? If so, all I need is a motor and I'm nearly ready to go.
Well it is 30" so it should work. What are trying to get and what is your zip?
Spike said:
I have an old 76 cm dish laying in my garage. How well would something like this work for FTA Ku-band reception?
Code:
 Hot Springs, SD 57747
Latitude 43° 25.338'N Longitude 103° 28.596'W
              Sat Name Sat Lng Az(t) Az(m)   El  Skew
          Intelsat 905   24.5W  97.6  87.5 -0.7 -46.0
          Intelsat 907   27.5W  99.7  89.6  1.4 -45.7
         Hispasat 1C/D   30.0W 101.5  91.4  3.2 -45.4
          Intelsat 801   31.5W 102.6  92.4  4.3 -45.1
          Intelsat 903   34.5W 104.8  94.6  6.5 -44.6
           AMC 12/T 11   37.5W 107.0  96.9  8.6 -44.0
               NSS 806   40.5W 109.3  99.1 10.7 -43.3
             Pas 3R/6B   43.0W 111.3 101.1 12.5 -42.6
                Pas 1R   45.0W 112.9 102.7 13.9 -42.0
          Intelsat 705   50.0W 117.0 106.8 17.3 -40.3
          Intelsat 707   53.0W 119.6 109.4 19.3 -39.2
          Intelsat 805   55.5W 121.8 111.6 21.0 -38.1
                 Pas 9   58.0W 124.1 113.9 22.6 -37.0
              Amazonas   61.0W 126.9 116.7 24.5 -35.5
            EchoStar 3   61.5W 127.4 117.2 24.8 -35.2
             Rainbow 1   61.5W 127.4 117.2 24.8 -35.2
              Nahuel 1   71.8W 138.1 127.9 30.7 -29.0
             DirecTV 1   72.5W 138.9 128.7 31.1 -28.5
                 AMC 6   72.0W 138.3 128.1 30.8 -28.9
             Galaxy 12   74.0W 140.6 130.4 31.8 -27.5
                 SBS 6   74.0W 140.6 130.4 31.8 -27.5
               GOES 12   75.0W 141.7 131.6 32.3 -26.7
                 AMC 5   79.0W 146.5 136.3 34.2 -23.6
             DirecTV 3   81.8W 150.0 139.8 35.4 -21.3
               Nimiq 2   82.0W 150.2 140.0 35.4 -21.1
          Brasilsat B3   84.0W 152.8 142.6 36.2 -19.4
              AMC 2/16   85.0W 154.1 143.9 36.6 -18.5
                 AMC 3   87.0W 156.7 146.5 37.2 -16.7
                  IA-8   89.0W 159.4 149.2 37.8 -14.8
             Galaxy 11   91.0W 162.2 152.0 38.4 -12.9
             Nimiq 1/3   91.0W 162.2 152.0 38.4 -12.9
          Brasilsat B4   92.0W 163.5 153.4 38.6 -11.9
             Telstar 6   93.0W 164.9 154.8 38.8 -10.9
             Galaxy 3C   95.0W 167.8 157.6 39.2  -8.9
             Telstar 5   97.0W 170.6 160.5 39.5  -6.8
             Galaxy 4R   99.0W 173.5 163.3 39.7  -4.7
       DirecTV 1R/4S/8  101.0W 176.4 166.2 39.9  -2.6
                 AMC 4  101.0W 176.4 166.2 39.9  -2.6
            Spaceway 1  102.0W 177.9 167.7 39.9  -1.6
                 AMC 1  103.0W 179.3 169.1 39.9  -0.5
                AMC 15  105.0W 182.2 172.0 39.9   1.6
           Anik F1/F1R  107.3W 185.6 175.4 39.8   4.0
             DirecTV 6  109.5W 188.7 178.6 39.5   6.3
            EchoStar 6  110.0W 189.4 179.3 39.5   6.8
            EchoStar 8  110.0W 189.4 179.3 39.5   6.8
               Anik F2  111.1W 191.0 180.8 39.3   8.0
         Solidaridad 2  113.0W 193.7 183.5 39.0   9.9
              SatMex 5  116.8W 199.0 188.8 38.1  13.7
             DirecTV 5  119.0W 202.0 191.8 37.5  15.8
            EchoStar 7  119.0W 202.0 191.8 37.5  15.8
 EchoStar 9/Telstar 13  121.0W 204.7 194.5 36.9  17.6
            Galaxy 10R  123.0W 207.3 197.1 36.2  19.4
             Galaxy 12  125.0W 209.8 199.7 35.4  21.2
         Galaxy 13/H 1  127.0W 212.3 202.2 34.6  22.9
  Telstar 7/Echostar 5  129.0W 214.8 204.6 33.7  24.5
                AMC 11  131.0W 217.2 207.0 32.8  26.0
             Galaxy 1R  133.0W 219.5 209.3 31.8  27.5
                AMC 10  135.0W 221.7 211.6 30.8  28.9
                 AMC 7  137.0W 223.9 213.8 29.7  30.3
                 AMC 8  139.0W 226.1 215.9 28.6  31.5
            EchoStar 1  148.0W 235.1 224.9 23.2  36.5
            EchoStar 2  148.0W 235.1 224.9 23.2  36.5
 *** DBS SATELLITE ***
         EchoStar 3/R1   61.5W 127.4 117.2 24.8 -35.2
          EchoStar 6/8  110.0W 189.4 179.3 39.5   6.8
            EchoStar 5  129.0W 214.8 204.6 33.7  24.5
          EchoStar 1/2  148.0W 235.1 224.9 23.2  36.5
             DirecTV 5  110.0W 189.4 179.3 39.5   6.8
            DirecTV 7S  119.0W 202.0 191.8 37.5  15.8
Satellite Finder is (c) Copyright 2004, P. Lutus
A 30" dish will work for 95% of all FTA channels, 99% of the time!
I'm located in Tennessee and speaking from my personal experience with my 76cm dish I can say that you may not be able to receive some of the weaker transponders up there, but for 96% of the Ku FTA stuff up there you should be fine.
LNB for 76cm
I would suggest to go with a invacom lnb.. would give you a little more juice than the standard FTA lnb to help with the 76cm dish.
The invacom is only .3db, giving you better signal quality, which is the more important than signal strength.
Spike
As noted above, most of the KU band stuff you can get with a 30" dish. For me, there has only been a handful of feeds (usually hockey games) that didnt have enough umph to keep it stable :)
(and that usually is weather related)
That would be a great start to your system :)
Ah! Thanks for the heads up on the LNB. I've ordered one, a single from Invacom. I hope to eventually upgrade to a C/Ku-Band LNB should one become available.
Again thanks!
I am using a 76 cm up here in northern vt, works ok for g10 but wish it was a little larger. Snow / rain fade is a definate issue with this dish.
The 30" will work for Ku band, but for C band you'll need at least 1.2 meters (MicroBUD!), and that won't get much. Most agree that 5 feet is the minimum for C band reception.
HD FTA Help
Cannot get Dolby Digital on Pansat 2700A
