Well, I finally got a 722K with OTA module after much ado with the CSR group. Thanks to Jason and Dan at CES, I got a hold of the right person at Dish to order the 722K and the 722K arrived on Thursday, the OTA module on Friday.
All seems well with it but I observed a strange problem and didn't see any threads on this in the past couple months search.
Here's the system, I have DPP LNB with a 61.5 side dish. I have a good solid ATSC signal from a roof top antenna reading 95-99 signal on all channels scanned in. The ATSC signal also runs to my 722 in the kitchen. The 722 works fine.
The problem was observed when I was recording one local channel using ATSC tuner and then tuned to another local channel to watch. The red record light was still on. In about 3 minutes of watching, a popup warning came up stating that I had lost my local channel signal and to call the station. Also, the red record light went out from the recording I had running on another channel. Upon checking, that recording never showed up in the DVR menu. Not even a remnant. I tuned up channel to another local and back to the original channel and it was back. It played fine. I tried to record a different local channel and watched that one at the same time and within a minute the popup again said I had lost signal, yet the other 722 still had signal on that same channel. I repeated this for several channels.
It appears that the OTA tuner works fine but will not record to DVR without the lost signal message. The sat tuner / DVR recordings all work fine.
Any idea what could be causing this? Has this been a bug ever reported before?
I will continue to try this for a few days and if no answers here, I report this to Echostar engineer contact.
PS- the 622 reboot issue I had with 4 - 622's last Fall has been resolved by Echostar engineering I understand. As I suggested it was a power supply issue where a connector was losing connection and the spring contacts were weak from heat over time. It would not be caught in the short testing they normally do during refurb. Some 622's would take a day of running before fail. I understand they are now replacing those connectors on all old 622's when sent back for refurb. They said they began doing this as of Dec 1.
