My 722K has locked up (cannot call guide up or change channels) 3 times in the last 3 days and I have to reset it. After the reset, it works just fine. Any suggestions as to what is going on?
PM Matt and move everything to an EHDD ASAP.My 722K has locked up (cannot call guide up or change channels) 3 times in the last 3 days and I have to reset it. After the reset, it works just fine. Any suggestions as to what is going on?
Expanding DVR StorageI'm assuming the ehdd means some kind of external hard drive? If so, how do I do this and what kind of connectors do I need?
Buy an external hard disc drive w/a USB 2 connector(w/power supply). Then hook it up to the USB out on the 722k. It will automatic recognize it and ask to format it. Once that is done you can move the vids to it. BTW I use the full term of EHDD to keep it from being confused w/ HD (high def). Get at least 500 Gb but I suggest you might want to go 1Tb. I use a docking station for mine so can change out the sata HDD w/o switching the docking station. Do the hard reboot as that never hurts.I'm assuming the ehdd means some kind of external hard drive? If so, how do I do this and what kind of connectors do I need?
