I receive the 61.5 cbs-hd when I connect direct to my 811. When I try to combine 119/110/61.5 on the DP34 switch, the switch wont find it (61.5) yet the signal shows 85-90. Do I need to change the LNB on the voom dish ?
Make sure you're using the same series of LNB on or 61.5 as the dish500. Since you quoted DP34 then I imagine your Dish500 LNB are the dishpro series. Check for the DP logo. The same series is required for the 61.5. You may need to buy a single dishpro LNB for 61.5 or possibly a complete 18 inchjmd102354 said:I receive the 61.5 cbs-hd when I connect direct to my 811. When I try to combine 119/110/61.5 on the DP34 switch, the switch wont find it (61.5) yet the signal shows 85-90. Do I need to change the LNB on the voom dish ?
It'll work since all of your lnbs are dp and you have the dp34. I'm not sure what's more expensive, the y-adapter & the lnb or the sw64 switch? But you definately have 2 options.jmd102354 said:I am getting a I-Adapter and a DP LNB for the Voom Dish. Should work . (i hope )
larrystotler said:Keep in mind that the I adapter may cause your dish to be a little off, so you may need to raise or lower it to compensate since it makes the LNB farther from the dish.
