D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 6/24/2009 12:29pm - 56 changes
Uplink Comparison Range: 06/24/2009 12:14P - 06/24/2009 12:29P
Channel Additions:
621 - GPUNJ [MPEG2 SD] added to Anik F3 118.7W TP 30 ConUS beam (NA)
6550(6) - WABG [MPEG2 SD] added to Ciel-2 129W TP 16 Spotbeam 38 (NA)(Greenwood, MS-ABC)
6551(15) - WXVT [MPEG2 SD] added to Ciel-2 129W TP 16 Spotbeam 38 (NA)(Greenville, MS-CBS)
6552(32) - WABGD [MPEG2 SD] added to Ciel-2 129W TP 16 Spotbeam 38 (NA)(Greenwood, MS-ABC)
6553(25) - WMAO [MPEG2 SD] added to Ciel-2 129W TP 16 Spotbeam 38 (NA)(Greenwood, MS-PBS)
Channel Removals:
596 - GLOBO (A) (H) removed from EchoStar1 148W TP 11 ConUS beam
640 - TVJPN (A) removed from EchoStar1 148W TP 11 ConUS beam
643 - ARTMV (A) (H) removed from EchoStar1 148W TP 11 ConUS beam
644 - LBC (A) (H) removed from EchoStar1 148W TP 11 ConUS beam
647 - NILE (A) removed from EchoStar1 148W TP 11 ConUS beam
648 - FUTUR (A) removed from EchoStar1 148W TP 11 ConUS beam
649 - DUBAI (A) removed from EchoStar1 148W TP 11 ConUS beam
659 - DUBSP (A) (H) removed from EchoStar1 148W TP 11 ConUS beam
670 - MBC (A) (H) removed from EchoStar1 148W TP 11 ConUS beam
776 - ALARA (A) removed from EchoStar1 148W TP 11 ConUS beam
785 - SETMX (A) removed from EchoStar1 148W TP 11 ConUS beam
792 - SET (A) (H) removed from EchoStar1 148W TP 11 ConUS beam
5253 - KBTZ (NA) removed from Ciel-2 129W TP 05 Spotbeam 12(Butte, MT-FOX)
5263 - KLMN (NA) removed from Ciel-2 129W TP 13 Spotbeam 6(Great Falls, MT-FOX)
5273 - KMMF (NA) removed from Ciel-2 129W TP 06 Spotbeam 11(Missoula, MT-FOX)
6112 - ALARA (A) (H) removed from EchoStar1 148W TP 01 ConUS beam
6113 - ARTMV (A) (H) removed from EchoStar1 148W TP 01 ConUS beam
6114 - LBC (A) (H) removed from EchoStar1 148W TP 25 ConUS beam
6115 - MBC (A) (H) removed from EchoStar1 148W TP 25 ConUS beam
6121 - DUBAI (A) (H) removed from EchoStar1 148W TP 09 ConUS beam
6122 - DUBSP (A) (H) removed from EchoStar1 148W TP 29 ConUS beam
6123 - FUTUR (A) (H) removed from EchoStar1 148W TP 09 ConUS beam
6124 - GLOBO (A) (H) removed from EchoStar1 148W TP 11 ConUS beam
6125 - SETMX (A) (H) removed from EchoStar1 148W TP 11 ConUS beam
6127 - SET (A) (H) removed from EchoStar1 148W TP 11 ConUS beam
6136 - NILE (A) (H) removed from EchoStar1 148W TP 09 ConUS beam
6142 - TVJPN (A) (H) removed from EchoStar1 148W TP 11 ConUS beam
7123 - KMMF (A) (H) removed from EchoStar10 110W TP 31 Spotbeam 37 (Missoula, MT-FOX)
7224 - KWBM (A) (H) removed from EchoStar10 110W TP 12 Spotbeam 20 (Harrison, AR-N/A)
7224 - KWBM (A) (H) removed from EchoStar8 77W TP 17 ConUS beam(Harrison, AR-N/A)
7923 - WBIF (A) (H) removed from EchoStar10 110W TP 04 Spotbeam 07 (Marianna, FL-RTN)
8539 - KUTF (A) (H) removed from EchoStar10 110W TP 23 Spotbeam 34 (Logan, UT-N/A)
8854 - KLMN (A) (H) removed from EchoStar10 110W TP 04 Spotbeam 36 (Great Falls, MT-FOX)
9090 - KBTZ (A) (H) removed from EchoStar10 110W TP 29 Spotbeam 37 (Butte, MT-FOX)
9130 - WNGS (A) (H) removed from EchoStar10 110W TP 27 Spotbeam 09 (Springville, NY-RTN)
Channel Package Flag Changes:
601 - ARTSP [MPEG2 SD] - Anik F3 118.7W TP 17 ConUS beam changed to Available
601 - ARTSP [MPEG2 SD] - EchoStar3 61.5W TP 14 ConUS beam changed to Available
606 - BBCAR [MPEG2 SD] - Anik F3 118.7W TP 17 ConUS beam changed to Available
606 - BBCAR [MPEG2 SD] - EchoStar3 61.5W TP 14 ConUS beam changed to Available
777 - HKYAT [MPEG2 SD] - Anik F3 118.7W TP 17 ConUS beam changed to Available
777 - HKYAT [MPEG2 SD] - EchoStar3 61.5W TP 14 ConUS beam changed to Available
829 - DNFYI [MPEG2 SD] - EchoStar7 119W TP 17 ConUS beam changed to Available
5180(7) - WKBW [MPEG4 HD] - Echostar12 61.5W TP 13 Spotbeam 4 changed to Available (H)(Buffalo, NY-ABC)
5251(13) - KVAL [MPEG4 HD] - Ciel-2 129W TP 14 Spotbeam 10 changed to Available (H)(Eugene, OR-CBS)
5251(2) - KBCI [MPEG4 HD] - Ciel-2 129W TP 04 Spotbeam 11 changed to Available (H)(Boise, ID-CBS)
5251(29) - KIMA [MPEG4 HD] - Ciel-2 129W TP 11 Spotbeam 5 changed to Available (H)(Yakima, WA-CBS)
5261(3) - KIDK [MPEG4 HD] - Ciel-2 129W TP 07 Spotbeam 12 changed to Available (H)(Idaho Falls, ID-CBS)
9073(48) - KVSN [MPEG2 SD] - EchoStar10 110W TP 04 Spotbeam 30 changed to Available (H)(Pueblo, CO-N/A)
19216 - HUNTV [DATA] - EchoStar11 110W TP 19 ConUS beam changed to Available
Channel Renames:
9645(99) - DPTC - EchoStar11 110W TP 10 ConUS beam renamed to V12 (A)
9645(99) - DPTC - EchoStar8 77W TP 29 ConUS beam renamed to V12 (A)
Channels in the system: 6562
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
Channel Additions:
Channel Removals:
Channel Renames:
