I will only be making the change from dish pro to legacy 1 time in the spring, and then back to dish pro in the fall. I currently have all the equipment needed and would rather not upgrade everything to dish pro. I have to install dish and everything this spring, so going through a "check switch' is no big deal. (I have an RV waver so I will not have to connect to phone line)
So to get this straight, I would disconnect the 522 from the current dish pro set up, then run a check switch, which will say no switch gear connected.
I will then hook up to legacy system, and run check switch. It should then tell me I have (2) sw21's.
I will then have to go to the installation and point dish screen to lock onto the satellite. Is this correct?
If so I am assuming the reverse procedure in the fall, however, I will not have to go through the point dish part, as that will remain installed at my house.
