Initially when I setup my dish with 522 receiver I don't have a cable subscription. So it was setup in such a way that, two cables were run from dish to the receiver. The output from the receiver to TV2 is connected to the existing wall jack (in house wiring). This is connected to the other cable which goes to the TV2 from the central location in the garage. This worked fine as long as I don't get any cable subscription. Now I need the cable and trying to figuring out how back feed can work in my situation.
Cable main feed comes to the garage central location. Now if I connect that with my wall jack in room 1 ie., TV1 room, then I will not have any outlet to TV2. After reading so much about the diplexers in this forum still I am confused whether there is any way I can get cable to my TV1, and using same cable send the TV2 output to the garage central location so that it can be connected to the TV2. I appreciate any input. Thanks.
