Here i go again!!!!
everytime i set up a fta and rtpi is a different problem.
So i started off with a universal digiwave lnb (very unpridictable).
so i switched to a standard linear lnb Qsat is the brand.
i'm using a viewsat extreme receiver to do this.
well i can't even get any signal strength. lnb frequency should be 11250 and i get nothing...
i put on 5150, and i do get signal strength, but then i go the transponder 11822, and signal is zero.
am I not setting up the lnb properly?
here are it's stats:
RF:11.70/12.20 GHz
IF:950/1450MHz
L.O.:10.750GHz
Gain:60dB
Noise Figure:0.3dB
Can someone help?
thanks
RF:11.70/12.20 GHz
IF:950/1450MHz
L.O.:10.750GHz
Gain:60dB
Noise Figure:0.3dB
Can someone help?
thanks
