D
DigiSAT Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 3/18/2009 12:55pm - 61 changes
Uplink Comparison Range: 03/18/2009 12:24P - 03/18/2009 12:55P
Channel Additions:
5103 - PPV [MPEG2 SD] added to EchoStar7 119W TP 06 ConUS beam (NA)
5103 - PPV [MPEG4 SD] added to EchoStar8 77W TP 21 ConUS beam (NA)
5250(9) - KGUN [MPEG4 HD] added to EchoStar7 119W TP 07 Arizona beam (NA)(Tucson, AZ-ABC)
5251(13) - KOLD [MPEG4 HD] added to EchoStar7 119W TP 07 Arizona beam (NA)(Tucson, AZ-CBS)
5252(4) - KVOA [MPEG4 HD] added to EchoStar7 119W TP 07 Arizona beam (NA)(Tucson, AZ-NBC)
5253(11) - KMSB [MPEG4 HD] added to EchoStar7 119W TP 07 Arizona beam (NA)(Tucson, AZ-FOX)
6477(4) - WTAE [MPEG4 HD] added to Ciel-2 129W TP 10 Spotbeam 26 (A) (H)(Pittsburgh, PA-ABC)
6478(2) - KDKA [MPEG4 HD] added to Ciel-2 129W TP 10 Spotbeam 26 (A) (H)(Pittsburgh, PA-CBS)
6479(11) - WPXI [MPEG4 HD] added to Ciel-2 129W TP 10 Spotbeam 26 (A) (H)(Pittsburgh, PA-NBC)
6480(53) - WPGH [MPEG4 HD] added to Ciel-2 129W TP 10 Spotbeam 26 (A) (H)(Pittsburgh, PA-FOX)
Channel Removals:
592 - RTVI (A) removed from EchoStar3 61.5W TP 18 ConUS beam
594 - HTBA (A) removed from EchoStar3 61.5W TP 18 ConUS beam
4608 - WTAE (NA) removed from Ciel-2 129W TP 10 Spotbeam 26(Pittsburgh, PA-ABC)
4609 - KDKA (NA) removed from Ciel-2 129W TP 10 Spotbeam 26(Pittsburgh, PA-CBS)
4610 - WPXI (NA) removed from Ciel-2 129W TP 10 Spotbeam 26(Pittsburgh, PA-NBC)
4611 - WPGH (NA) removed from Ciel-2 129W TP 10 Spotbeam 26(Pittsburgh, PA-FOX)
5731 - WXIA (A) (H) removed from EchoStar7 119W TP 15 ConUS beam(Atlanta, GA-NBC)
5733 - WGCL (A) (H) removed from EchoStar7 119W TP 15 ConUS beam(Atlanta, GA-CBS)
5735 - WSB (A) (H) removed from EchoStar7 119W TP 15 ConUS beam(Atlanta, GA-ABC)
5737 - WAGA (A) (H) removed from EchoStar7 119W TP 15 ConUS beam(Atlanta, GA-FOX)
6132 - HTBA (A) (H) removed from EchoStar3 61.5W TP 14 ConUS beam
6133 - RTVI (A) (H) removed from EchoStar3 61.5W TP 14 ConUS beam
9467 - HDPPV (A) removed from EchoStar11 110W TP 13 ConUS beam
9467 - HDPPV (A) removed from Echostar6 72.7W TP 17 ConUS beam
Channel Moves:
7023 - KTAB [MPEG2 SD] moved from EchoStar1 148W TP 31 ConUS beam to EchoStar1 148W TP 03 ConUS beam (A) (H)(Abilene, TX-CBS)
7024 - KRBC [MPEG2 SD] moved from EchoStar1 148W TP 31 ConUS beam to EchoStar1 148W TP 03 ConUS beam (A) (H)(Abilene, TX-NBC)
7061 - KLST [MPEG2 SD] moved from EchoStar1 148W TP 15 ConUS beam to EchoStar1 148W TP 03 ConUS beam (A) (H)(San Angelo, TX-CBS)
7062 - KSAN [MPEG2 SD] moved from EchoStar1 148W TP 15 ConUS beam to EchoStar1 148W TP 03 ConUS beam (A) (H)(San Angelo, TX-NBC)
9650 - HDBTV [MPEG4 HD] moved from EchoStar9 121W TP 02 ConUS beam to EchoStar9 121W TP 17 ConUS beam (A)
9651 - HDBT2 [MPEG4 HD] moved from EchoStar9 121W TP 02 ConUS beam to EchoStar9 121W TP 17 ConUS beam (A)
15204 - WAHU1 [EPG] moved from EchoStar11 110W TP 02 ConUS beam to Ciel-2 129W TP 15 Spotbeam 39 (NA)(Charlottesville, VA-N/A)
15205 - WAHU2 [EPG] moved from EchoStar11 110W TP 02 ConUS beam to Ciel-2 129W TP 15 Spotbeam 39 (NA)(Charlottesville, VA-N/A)
15206 - WHTJ1 [EPG] moved from EchoStar11 110W TP 02 ConUS beam to Ciel-2 129W TP 15 Spotbeam 39 (NA)(Charlottesville, VA-PBS)
15207 - WHTJ3 [EPG] moved from EchoStar11 110W TP 02 ConUS beam to Ciel-2 129W TP 15 Spotbeam 39 (NA)(Charlottesville, VA-PBS)
15208 - WVAW1 [EPG] moved from EchoStar11 110W TP 02 ConUS beam to Ciel-2 129W TP 15 Spotbeam 39 (NA)(Charlottesville, VA-N/A)
Channel Package Flag Changes:
583 - RADIO [MPEG AUDIO] - EchoStar1 148W TP 01 ConUS beam changed package flags (A)
583 - RADIO [MPEG AUDIO] - EchoStar3 61.5W TP 12 ConUS beam changed package flags (A)
674 - INDMU [MPEG2 SD] - Anik F3 118.7W TP 28 ConUS beam changed package flags (A)
674 - INDMU [MPEG2 SD] - EchoStar1 148W TP 27 ConUS beam changed package flags (A)
756 - RDSLZ [MPEG AUDIO] - Anik F3 118.7W TP 22 ConUS beam changed package flags (A)
757 - TVSLZ [MPEG2 SD] - Anik F3 118.7W TP 22 ConUS beam changed package flags (A)
810 - RADIO [MPEG AUDIO] - Anik F3 118.7W TP 01 ConUS beam changed package flags (A)
5184(4) - WTTV [MPEG4 HD] - EchoStar5 129W TP 05 ConUS beam changed to Available (H)(Bloomington, IN-N/A)
5250(10) - WDIO [MPEG4 HD] - Ciel-2 129W TP 02 Spotbeam 9 changed to Available (H)(Duluth, MN-ABC)
5250(23) - KERO [MPEG4 HD] - Ciel-2 129W TP 10 Spotbeam 32 changed to Available (H)(Bakersfield, CA-ABC)
5250(3) - KIII [MPEG4 HD] - Ciel-2 129W TP 13 Spotbeam 52 changed to Available (H)(Corpus Christi, TX-ABC)
5250(35) - KAPP [MPEG4 HD] - Ciel-2 129W TP 11 Spotbeam 5 changed to Available (H)(Yakima, WA-ABC)
5251(10) - KZTV [MPEG4 HD] - Ciel-2 129W TP 13 Spotbeam 52 changed to Available (H)(Corpus Christi, TX-CBS)
5251(3) - KDLH [MPEG4 HD] - Ciel-2 129W TP 02 Spotbeam 9 changed to Available (H)(Duluth, MN-CBS)
5252(17) - KGET [MPEG4 HD] - Ciel-2 129W TP 10 Spotbeam 32 changed to Available (H)(Bakersfield, CA-NBC)
5252(25) - KNDU [MPEG4 HD] - Ciel-2 129W TP 11 Spotbeam 5 changed to Available (H)(Richland, WA-NBC)
5252(6) - KBJR [MPEG4 HD] - Ciel-2 129W TP 02 Spotbeam 9 changed to Available (H)(Superior, WI-NBC)
5252(6) - KRIS [MPEG4 HD] - Ciel-2 129W TP 13 Spotbeam 52 changed to Available (H)(Corpus Christi, TX-NBC)
5253(21) - KQDS [MPEG4 HD] - Ciel-2 129W TP 02 Spotbeam 9 changed to Available (H)(Duluth, MN-FOX)
7934(32) - WVIRD [MPEG2 SD] - Ciel-2 129W TP 15 Spotbeam 39 changed to Available (H)(Charlottesville, VA-NBC)
8166(40) - WMGM [MPEG2 SD] - EchoStar10 110W TP 12 Spotbeam 04 changed to Available (H)(Wildwood, NJ-NBC)
8166(40) - WMGM [MPEG4 SD] - Echostar12 61.5W TP 11 Area 5 beam changed to Available (H)(Wildwood, NJ-NBC)
8417(26) - KODF [MPEG2 SD] - EchoStar10 110W TP 29 Spotbeam 21 changed to Available (H)(Britton, TX-N/A)
8417(26) - KODF [MPEG4 SD] - Echostar12 61.5W TP 01 Area 3 beam changed to Available (H)(Britton, TX-N/A)
19210 - FANDO [DATA] - EchoStar11 110W TP 06 ConUS beam changed package flags (A)
Channel Renames:
9990 - DTV - EchoStar11 110W TP 08 ConUS beam renamed to ETC10 (A) (H)
Channels in the system: 6413
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
Channel Additions:
Channel Removals:
Channel Moves:
Channel Renames:
