I have three 211k receivers connected to a SW34 switch. One of the receivers is seeing a +150 drift on the 129 LNB - this causes many of my HD channels to show total signal loss. The other two show no LNB drift. I have physically replaced the LNB. I have physically swapped the "bad" receiver with one of the "good" receivers. I did a check switch on both and a sys info. Nothing changed. The "bad" receiver still showed the +150 drift and the "good" receiver showed zero drift. I would think that would rule out the LNB, the wiring, and the switch.
Can a receiver flake out and behave this way? Is my only option to replace the receiver - it is purchased?
