Brady suspended ?This actually was the first thought that came to my mind after hearing about the 11 out of 12 balls found deflated.
New England Patriots Disqualified From Super Bowl? Momentum Growing To Kick Patriots Out After Cheating Scandal
http://www.inquisitr.com/1775216/ne...-to-kick-patriots-out-after-cheating-scandal/
The "momentum" is most likely momentum in public polls leaning towards banning the Patriots from the Super Bowl,SOMETHING THE NFL WILL NEVER DO.
The most likely realistic punishments will be a very stiff 7 digit fine,loss of a first round draft pick,& maybe,based on the Bountygate punishments,Belichick & Brady suspended for the entire 2015 Football season,with maybe,but very unlikely,owner Kraft also suspended for that season.
What great viewing that would be ...Suspend Bellichick permanently,Brady 1 full season,bar Pats from sb,and give it the trophy to Seattle via forfiet,would be a fitting punishment imo.
It's Gisele's fault!!!!! Gisele did it.
A bit harsh.Suspend Bellichick permanently,Brady 1 full season,bar Pats from sb,and give it the trophy to Seattle via forfiet,would be a fitting punishment imo.
No, he's guilty of being a repeat offender by being previously caught cheating..
If you noticed, they were 2 seperate sentences (hence the period), the first about Bellicheck's repeated cheating.Yup you're right sir , Spygate was all BRADY!![]()
Hard to deny it when you were caught red handedAnother point, during Spygate (which in my opinion is much worse than this), BB fully cooperated w/ the league and admitted it. Not once did he deny it.
If the environment could significantly alter the physical properties of a football that much, Wilson and the NFL for that matter would have had big problems before now....What was the temp indoors? 74degrees minimum.... difference of 25degrees, plus thow in wind and rain.
Also, where the "proper" balls at the end of the game also weighed?
