2/8/2010 9:46pm - Uplink Activity Report - 34 changes
The other issue you face in Maine is that if E3 fails at 61.5 and they switch over stuff to E6, you may not be able to see it. E6's footprint was designed for 110/119 and really does not hit Maine well from 61.5. It might be trouble until E15 goes up and replaces E3.
This could be part of the reason they decided to move stuff to 72 and 77. E6 at 61.5 hits the center of the Eastern half of the country pretty well, but if you live in the upper half of Maine or the lower half of TX you are in trouble. I attached the map from Dish's application to move E6 to 61.5
Now, that makes everything worse. It's going to really hard to for us to pick up 77. And we can't pick up 129. I guess Maine is Screwed all together.
Josh
I got word that the following HD channels are launching this week. All channels will be on 129. TRUTV hd
FOX SOCCER CHANNEL HD
Retro Hd
BBC America hd
E! Entertainment Television HD
Indie Hd
Sportsman hd
Hallmark HD
Showtime HD (west)
Only BBC America will be on 61.5 all other new HD channels will be on 72.5.
Scott, should we read this as no agreement with Epix or the agreement falling apart?
I have a D500+ with 61.5 as a wing dish. If I mount a LNB opposite the 110 LNB with bracket, so you have from behind dish 129, 119/118.7, 110 would that make it a D1000.2? Is the reflector the same size? I would not want to reposition 61.5 because of location, hard to get to. Thanks
Yeah this would be cool and if this is just phase 1 be interesting to see what else they can add.
I think Dish is counting on the fact that most subs are ignorant to new channels being added. It's only the more knowledgeable ones like us that are aware we are getting screwed. :)
Bingo!
Of course there's an outside chance, as Scott will readily admit, that the sources telling him these channels won't be on 61.5 are as wrong as the ones who told him they would be. :)
If Dish does do this then the sat at 61.5 must really be falling apart. It's a drastic step (IMO). And there's no way of telling if or when we who have 110/119/61.5 setups will get these (or other) additional channels. We just need to assume the necessity of switching to EA or to another provider.
In my case I also have cable, which has E!-HD and TruTV HD. I don't care about the movie channels; the only channels I'd like to have are FSC-HD and BBC-A HD and it appears I'll get the second one. So no big deal for me but I'm sure it will enrage others who rely on 61.5.
When I go to the Dish retailer website and I enter my zip code this is what it states below:
Closest Records to: Claremont, NH
1 Records Found (displaying 1 to 1)
Western Arc DMA, You may use both MPEG2 and MPEG 4 Equipment.
Burlington et al VT-NY,
But, if I do this I will not be able to receive local HD channels since they are on 61.5.
This doesn't make sense.
Scott, would this information above be accurate?
Thanks!
Bingo!
Nope take a look at last nights uplink report, and that goes with some internal documents that I was sent shortly after "The Scotty Chat" went off the air.
It looks like they wil launch on 129 and 72.7.
Yea, well, it was worth a shot, as I really would like FSC-HD.
I would probably call and see if I could get EA installed but, even if they would do it, I would probably need to re-up for another 2 years (I'm currently out-of-contract) and with FIOS so close (they're pulling the fiber into the complex as I type) I really don't want to commit.
Thanks for posting that (depressing) news.
The plans were to put it on 61.5 but with the satellite issues on 61.5 the past few weeks they couldnt do it.
They have to launch these channels so this is how they are doing it for now. I do expect them to migrate when E6 is moved to 61.5.
Interesting dilemma...
A friend of mine has a mixture of receivers (722, 622, and 522).
Our HD-Locals are on 77. So to support that and the non-vip 522 he has 61.5, 77, 110 & 119 going into a DPP-44 switch.
To get those new HD channels, 72 will now need to be entered into the mix. I wonder if Dish will swap out his 522 for a 612 for free in order to get everything since they don't support 5 sat. setups?
So, I have 61.5. I should just swing that around to 129, run check switch, etc. Im assuming 72.7 needs a differnet type of LNB?
OK,
I have a 1000.2 dish (I think?). I believe I am on western arc, I have 110 / 119 / 129 satellites.
What will I have to do to get BBC America on 61.5 and all the other new HD channels on 72.5?
Like Scott said, all will be fine for you but I would consider "future proofing" your setup by adding a wing dish pointing to 61.5. This will connect to your 1000.2 without the need for a switch and you should be able to pickup a dish to point to the 61.5 cheap. I used an older 1000 to point to the 61.5 and it's connected to my 1000.2 pointing to the usual 110/119/129.
Once similiarly set up, you won't have any concerns about receiving any new programming.
Baikonur (spelling?) Cosmodrome my a**! :)
Funny how the worm turns. Wasn't it just last year this time (or perhaps a bit further back) that those pointed at 129 were at the mercy of a failing satellite?
so If I have a dish pointed at 110,119 and 129.will I get all the new channels.i'm in the eastern area.but what is ea?
As stated earlier, ALL of the new channels will be on 129. You will receive all of them provided you have the proper subscriptions. We don't know that criteria yet.
D
3/10/2010 3:06pm - Uplink Activity Report - 27 changes
D
3/15/2010 2:07pm - Uplink Activity Report - 4 changes
