2 3/8" pipe question
iafirebuff
4,394
8
Waterloo, Iowa
Gonna head out tomorrow to get some cement and pipe for the Primestar project. Just curious, 2 3/8" pipe - about what does that run on average, and what department in Lowes or Home Depot shold I look? Thanks!
The chain link fence section - fence posts. I use the 1 5/8" so I can put any dish on it. Make a spacer from split plastic pipe to attach a larger dish, add a ground jumper across the plastic.
I would check the chain link fence section first. Worse case scenario you can use Galvanized pipe, but it will run you $30/$40
Just a suggestion, take the Dish with you to Home Depot when you buy the pipe! Even knowing as much as I know, I have gotten ID and OD screwed up on something of an odd size like this.
I can't help on the department question, just wanted to say, I got mine from a local fence company. Don't remember the price, but it seems like maybe $30 or so. 8' x 2 3/8" schedule 40.
Al
Thanks! I have about 20 feet of 2" galv. heavy duty grade flag pole I took down. lets see if I have this right - I can use the smaller size, then take a piece of plastic pipe and put that over the 2", then mount the dish. This tightens down good then? That might be the way to go!
8 foot 2 3/8 regular galvanized fence pipe is $13 at home depot, that's what I used. I wouldn't call it 'rock" solid but it's doing the job quite nicely.
:hatsoff:
If you want to take the dish with you, just take the bracket off the back...much easier to handle that :)
If I remember correctly, all of my P* dishes use a 1 5/8 pipe. that's what I had cemented in the ground, the when I took that down and put up a polar mount from an old 10' dish, I just bought longer lag-bolts that are used to secure the 2 1/2" polar mount to my 1 5/8" mount.....bottom line, make sure you don't get too large diameter pipe in the ground then find out you can't fit your P* dish on the pipe!
And I would probably get less looks too :) But, it might be fun to go in carrying a Primestar dish ;-) I measured the opening to the mount, and 2 3/8's pipe should work. Now I got to figure out what to do with my old flag pole I took down. :)
Thanks, I will double check before anything goes into the cement. I did measure the mount last night, and it was over 2". My 2" pipe just swims in the mount :)
sikma
I have 2 (use to have 3) DirecPC/Primestar dishes and they all took 2 3/8" pipe. My SC dish takes a 2" pipe
Ice - want about 20' of 2" galv. flag pole pipe? Strong stuff! I hate to let it go to waste :) Of course driving 500 miles would be pretty costly :) My father in law has been asking lots of questions on my projects. He has an old cband and a Dish Network. He is eyeballing one of the Primestar dishes...... he wants to see about using it for Dish, to avoid rain fade. :)
I use a chain link cornerpost for my Andrew and the DirecPC dish. Work great.
Recording sound for PBS channels to vcr
GeoSatPro 90cm and Fortec 90cm Dish
