SatelliteGuys.US DishNetwork Uplink Report - 12/31/2014 22:53 - 78 Changes
Uplink Comparison Range: 12/31/2014 22:47 - 12/31/2014 22:53 (PST)
MAP Changed:
4971 - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS renamed to LOCAL , changed to Available , map (32) added (LOCAL)(Mkt: Honolulu,HI)(A)(H)
4971 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (32) added (LOCAL)(Mkt: Honolulu,HI)(A)(H)
4972 - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS renamed to LOCAL , changed to Available , map (49) added (LOCAL)(Mkt: Fresno,CA)(A)(H)
4972 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (49) added (LOCAL)(Mkt: Fresno,CA)(A)(H)
4973 - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS renamed to LOCAL , changed to Available , map (15) added (LOCAL)(Mkt: Honolulu,HI)(A)(H)
4973 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (15) added (LOCAL)(Mkt: Honolulu,HI)(A)(H)
4974 - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS renamed to LOCAL , changed to Available , map (38) added (LOCAL)(Mkt: Sioux Falls,SD)(A)(H)
4974 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (38) added (LOCAL)(Mkt: Sioux Falls,SD)(A)(H)
4975 - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS renamed to LOCAL , changed to Available , map (5) added (LOCAL)(Mkt: Anchorage,AK)(A)(H)
4975 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (5) added (LOCAL)(Mkt: Anchorage,AK)(A)(H)
4976 - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS renamed to LOCAL , changed to Available , map (6) added (LOCAL)(Mkt: Anchorage,AK)(A)(H)
4976 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (6) added (LOCAL)(Mkt: Anchorage,AK)(A)(H)
4977 - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS renamed to LOCAL , changed to Available , map (15) added (LOCAL)(Mkt: Orlando,FL)(A)(H)
4977 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (15) added (LOCAL)(Mkt: Orlando,FL)(A)(H)
4978 - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS renamed to LOCAL , changed to Available , map (61) added (LOCAL)(Mkt: West Palm Beach,FL)(A)(H)
4978 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (61) added (LOCAL)(Mkt: West Palm Beach,FL)(A)(H)
4979 - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS renamed to LOCAL , changed to Available , map (62) added (LOCAL)(Mkt: Chicago,IL)(A)(H)
4979 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (62) added (LOCAL)(Mkt: Chicago,IL)(A)(H)
4980 - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS renamed to LOCAL , changed to Available , map (49) added (LOCAL)(Mkt: Burlington,VT)(A)(H)
4980 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (49) added (LOCAL)(Mkt: Burlington,VT)(A)(H)
4981 - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS renamed to LOCAL , changed to Available , map (64) added (LOCAL)(Mkt: Grand Rapids,MI)(A)(H)
4981 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (64) added (LOCAL)(Mkt: Grand Rapids,MI)(A)(H)
4982 - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS renamed to LOCAL , changed to Available , map (25) added (LOCAL)(Mkt: New York,NY)(A)(H)
4982 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (25) added (LOCAL)(Mkt: New York,NY)(A)(H)
4983 - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS renamed to LOCAL , changed to Available , map (20) added (LOCAL)(Mkt: Charleston,WV)(A)(H)
4983 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (20) added (LOCAL)(Mkt: Charleston,WV)(A)(H)
4984 - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS renamed to LOCAL , changed to Available , map (48) added (LOCAL)(Mkt: New York,NY)(A)(H)
4984 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (48) added (LOCAL)(Mkt: New York,NY)(A)(H)
4985 - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS renamed to LOCAL , changed to Available , map (56) added (LOCAL)(Mkt: Washington,DC)(A)(H)
4985 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (56) added (LOCAL)(Mkt: Washington,DC)(A)(H)
4993 - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS renamed to LOCAL , changed to Available , map (34) added (LOCAL)(Mkt: Savannah,GA)(A)(H)
4993 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (34) added (LOCAL)(Mkt: Savannah,GA)(A)(H)
4994 - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS renamed to LOCAL , changed to Available , map (48) added (LOCAL)(Mkt: El Paso,TX)(A)(H)
4994 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (48) added (LOCAL)(Mkt: El Paso,TX)(A)(H)
4995 - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS renamed to LOCAL , changed to Available , map (53) added (LOCAL)(Mkt: Washington,DC)(A)(H)
4995 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (53) added (LOCAL)(Mkt: Washington,DC)(A)(H)
4998 - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS renamed to LOCAL , changed to Available , map (3) added (LOCAL)(Mkt: Albuquerque,NM)(A)(H)
4998 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (3) added (LOCAL)(Mkt: Albuquerque,NM)(A)(H)
5001 - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS renamed to LOCAL , changed to Available , map (35) added (LOCAL)(Mkt: Seattle,WA)(A)(H)
5001 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (35) added (LOCAL)(Mkt: Seattle,WA)(A)(H)
5167(49) - WLED [MPEG4 HD] Echostar16 61.5W TP 30 Spotbeam 50 changed to Not Available , map (49) removed (Stn: (LITTLETON,VT-PBS) (VT-PBS))(NA)(H)
5171(15) - WDSC [MPEG4 HD] Echostar16 61.5W TP 22 Spotbeam 11 changed to Not Available , map (15) removed (Stn: (NEW SMYRNA BEACH,FL-PBS) (FL-PBS))(NA)(H)
5171(15) - WDSC [MPEG4 HD] Ciel-2 129W TP 05 Spotbeam 53 changed to Not Available , map (15) removed (Stn: (NEW SMYRNA BEACH,FL-PBS) (FL-PBS))(NA)(H)
5259(48) - KTDO [MPEG4 HD] EchoStar14 119W TP 01 Spotbeam A23 changed to Not Available , map (48) removed (Stn: (LAS CRUCES,NM-Telemundo) (NM-Telemundo))(NA)(H)
5266(34) - WGSA [MPEG4 HD] Echostar16 61.5W TP 29 Spotbeam 33 changed to Not Available , map (34) removed (Stn: (BAXLEY,GA-CW) (GA-CW))(NA)(H)
5266(34) - WGSA [MPEG4 HD] Ciel-2 129W TP 11 Spotbeam 44 changed to Not Available , map (34) removed (Stn: (BAXLEY,GA-CW) (GA-CW))(NA)(H)
6318(25) - WNYE [MPEG4 HD] Echostar16 61.5W TP 24 Spotbeam 02 changed to Not Available , map (25) removed (Stn: (NEW YORK,NY-IND) (NY-IND))(NA)(H)
7035(5) - KYES [MPEG2 SD] EchoStar14 119W TP 01 Spotbeam A24 changed to Not Available , map (5) removed (Stn: (ANCHORAGE,AK-MN) (AK-MN))(NA)(H)
7037(6) - KYESD [MPEG2 SD] EchoStar14 119W TP 01 Spotbeam A24 changed to Not Available , map (6) removed (Stn: (ANCHORAGE,AK-IND) (AK-IND))(NA)(H)
7322(20) - WOUB [MPEG4 SD] Echostar16 61.5W TP 26 Spotbeam 32 changed to Not Available , map (20) removed (Stn: (ATHENS,WV-PBS) (WV-PBS))(NA)(H)
7322(20) - WOUB [MPEG2 SD] Ciel-2 129W TP 09 Spotbeam 31 changed to Not Available , map (20) removed (Stn: (ATHENS,WV-PBS) (WV-PBS))(NA)(H)
7485(34) - WGSA [MPEG2 SD] EchoStar14 119W TP 04 Spotbeam B18 changed to Not Available , map (34) removed (Stn: (BAXLEY,GA-CW) (GA-CW))(NA)(H)
7592(48) - KTDO [MPEG2 SD] EchoStar10 110W TP 29 Spotbeam 31 changed to Not Available , map (48) removed (Stn: (LAS CRUCES,NM-Telemundo) (NM-Telemundo))(NA)(H)
8077(56) - WNVC [MPEG4 SD] Echostar16 61.5W TP 20 Spotbeam 52 changed to Not Available , map (56) removed (Stn: (FAIRFAX,VA-IND) (VA-IND))(NA)(H)
8077(56) - WNVC [MPEG2 SD] EchoStar14 119W TP 05 Spotbeam B16 changed to Not Available , map (56) removed (Stn: (FAIRFAX,VA-IND) (VA-IND))(NA)(H)
8084(53) - WNVT [MPEG4 SD] Echostar16 61.5W TP 20 Spotbeam 52 changed to Not Available , map (53) removed (Stn: (GOLDVEIN,VA-IND) (VA-IND))(NA)(H)
8084(53) - WNVT [MPEG2 SD] EchoStar14 119W TP 05 Spotbeam B16 changed to Not Available , map (53) removed (Stn: (GOLDVEIN,VA-IND) (VA-IND))(NA)(H)
8114(25) - WNYE [MPEG2 SD] EchoStar10 110W TP 20 Spotbeam 04 changed to Not Available , map (25) removed (Stn: (NEW YORK,NY-IND) (NY-IND))(NA)(H)
8116(48) - WRNN [MPEG4 SD] Echostar16 61.5W TP 24 Spotbeam 02 changed to Not Available , map (48) removed (Stn: (KINGSTON,NY-IND) (NY-IND))(NA)(H)
8116(48) - WRNN [MPEG2 SD] EchoStar10 110W TP 20 Spotbeam 04 changed to Not Available , map (48) removed (Stn: (KINGSTON,NY-IND) (NY-IND))(NA)(H)
8281(15) - WDSC [MPEG2 SD] EchoStar10 110W TP 12 Spotbeam 01 changed to Not Available , map (15) removed (Stn: (NEW SMYRNA BEACH,FL-PBS) (FL-PBS))(NA)(H)
8503(62) - WJYS [MPEG4 SD] Echostar16 61.5W TP 20 Spotbeam 55 changed to Not Available , map (62) removed (Stn: (HAMMOND,IN-IND) (IN-IND))(NA)(H)
8503(62) - WJYS [MPEG2 SD] EchoStar10 110W TP 31 Spotbeam 19 changed to Not Available , map (62) removed (Stn: (HAMMOND,IN-IND) (IN-IND))(NA)(H)
8622(35) - KVOS [MPEG2 SD] EchoStar14 119W TP 05 Spotbeam A1 changed to Not Available , map (35) removed (Stn: (BELLINGHAM,WA-MeTV) (WA-MeTV))(NA)(H)
8717(64) - WLLA [MPEG4 SD] Echostar16 61.5W TP 19 Spotbeam 54 changed to Not Available , map (64) removed (Stn: (KALAMAZOO,MI-IND) (MI-IND))(NA)(H)
8717(64) - WLLA [MPEG2 SD] EchoStar10 110W TP 12 Spotbeam 13 changed to Not Available , map (64) removed (Stn: (KALAMAZOO,MI-IND) (MI-IND))(NA)(H)
8820(3) - KENW [MPEG2 SD] EchoStar14 119W TP 02 Spotbeam B8 changed to Not Available , map (3) removed (Stn: (PORTALES,NM-PBS) (NM-PBS))(NA)(H)
8867(61) - WFGC [MPEG4 SD] Echostar16 61.5W TP 18 Spotbeam 57 changed to Not Available , map (61) removed (Stn: (PALM BEACH,FL-IND) (FL-IND))(NA)(H)
8867(61) - WFGC [MPEG2 SD] EchoStar14 119W TP 04 Spotbeam B20 changed to Not Available , map (61) removed (Stn: (PALM BEACH,FL-IND) (FL-IND))(NA)(H)
8906(32) - KBFD [MPEG2 SD] EchoStar14 119W TP 05 Spotbeam A27 changed to Not Available , map (32) removed (Stn: (HONOLULU,HI-IND) (HI-IND))(NA)(H)
8910(15) - KUPU [MPEG2 SD] EchoStar14 119W TP 05 Spotbeam A27 changed to Not Available , map (15) removed (Stn: (WAIMANALO,HI-IND) (HI-IND))(NA)(H)
8944(49) - WLED [MPEG2 SD] EchoStar10 110W TP 26 Spotbeam 04 changed to Not Available , map (49) removed (Stn: (LITTLETON,VT-PBS) (VT-PBS))(NA)(H)
8976(49) - KNXT [MPEG2 SD] EchoStar10 110W TP 04 Spotbeam 38 changed to Not Available , map (49) removed (Stn: (VISALIA,CA-IND) (CA-IND))(NA)(H)
9237(38) - KWSD [MPEG2 SD] EchoStar10 110W TP 23 Spotbeam 32 changed to Not Available , map (38) removed (Stn: (SIOUX FALLS,SD-MeTV) (SD-MeTV))(NA)(H)
Name Changed:
269 - VALU [MPEG4 SD] Nimiq5 72.7W TP 31 ConUS renamed to REAL (REAL (Adult Ch) -web site not appropriate for work)(A)(FP)
269 - VALU [MPEG2 SD] EchoStar11 110W TP 10 ConUS renamed to REAL (REAL (Adult Ch) -web site not appropriate for work)(A)(FP)
9644(94) - VALU [MPEG4 SD] Nimiq5 72.7W TP 31 ConUS renamed to REAL (REAL (Adult Ch) -web site not appropriate for work)(A)(FP)
9644(94) - VALU [MPEG2 SD] EchoStar11 110W TP 10 ConUS renamed to REAL (REAL (Adult Ch) -web site not appropriate for work)(A)(FP)
Channels in the system: 9551
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2014 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
SatelliteGuys Uplink PC Version 1.0.0
© 2014 - All Rights Reserved - SatelliteGuys Incorporated.
MAP Changed:
Name Changed:
(FP) = Free Preview
