Just recently, I have not been able to get 110/119 signals simultaneously. I can get 110 or 119, but not both. 119 has been weak for a while, but I could get ok signal at night. So, I decided to try to fix it. This is quite perplexing. If I loosen the screw that holds LNB-C (110) in place, I get excellent signal strength on 110, but none on 119. If I tighten the screw, 110 goes away and 119 comes back. So, loosening and tightening the screw on LNB-C changes whether I receive 110 or 119. I get a good signal on one, but the other is flat.  Also, depending on the time of day, I may receive the 110 signal and then later in the day the 119 signal.
My receiver is the Hughes HD-86 with the combined LNB adapter multiswitch on the dish. I have had this configuration for 2.5 years.
Thanks.
Thanks.
