I recently bought a 2m (6'+) HDMI Monster 400 cable off Ebay from Accessories4less for $69.99. This cable has a street value of $119.99. Great service and free delivery. Received cable in 3 days.
Briguy said:But back to my last post since I am a novice at this my Sony KDF- E42A10 would take a straight HDMI male to male cable but because my Yamaha reciever is about 5 years old I would still need to take RCA cables from the 622 to the Yamaha for audio?
Bingo! Sounds like a winner. Buy an optical/TOSlink cable and hook er up. Then sit back and enjoy the best sound your 622 can put out.Briguy said:I am only seeing RCA inputs for audio however their is a section on the back of my yamaha for Digital signal both coxial and optical.
BuddTX said:Now the HDMI cable has to meet the specificaltions for HDMI (two dixi cups and a waxed string will not work!), but after that, there is no difference, as long as the cable works.
Sure there are quality issues, cheap connectors vs well made connectors, quality of construction, and, or course, better cables made cables may cost more than cheaply made cables.
But, if a 5 dollar HDMI cable is working, you will NOT see any difference by using a 100 dollar hdmi cable, as long as they both work. It is all ZERO's and ONE's, the data either gets transfered, or it does not.
Max Wright said:Let me add another question into the foray. I have an input on my TV for an HDMI however the cord I'm utilizing is HDMI to DVI cord. There then is a DVI to HDMI adaptor connected. Is it better to have an HDMI to HDMI cord rather than have to use this adaptor? Common sense says that the more connections that is made the more likely something is connected right away. Regardless I think I'll like it without the adaptor just to cut down on the bulk behind the TV.
My Hitachi has an input port where I can use it's speakers as the Center Speaker for my stereo's 5.1 surroundTom Bombadil said:You could eliminate them if you are using your TV's built-in speakers.
Ick!
I don't even know if the speakers in my HDTV work, I've never connected them, even for a test.
jayn_j said:All that said, it probably won't make much of a practical difference on your setup. I would be more worried about that DVI-DVI link adding stress to the HDMI connector over time. I have a spot where I have something similar and invested some time in adding stress relief. That can be as simple as blocking the connector up with something to relieve the downward stress.
Derwin0 said:My Hitachi has an input port where I can use it's speakers as the Center Speaker for my stereo's 5.1 surround![]()
