Last Friday, I excitedly began the installation of my DG380 Motor attached on a 1.2M Geosat pro Dish and mounted on the second floor beam of my building. After I got someone to help me get the Dish on the pole mount and bubble balanced, I set the Latitude on my Motor to 42.7° approximately, and my dish elevation to 33.5°. (Note, the original elevation was supposed to be 29°, but as I had to invert the mount on the Dish to accommodate the Motor, I added 4.5° as prescribed by the manual to compensate.) I reset the motor to “0” using my Coolsat 5K, and then using USUALS to motor to 72.0W° which is my most southern satellite. For over 3 hours I panned east to west. Tilted up & down on the Dish elevation and Azimuth trying to lock on Transponders 12143 V 2573 or 12068 V 9755 (Is 12143 V still active, because Lyngsat doesn’t have SR listed for that frequency). This was maybe my final attempt to install my motorized Dish before the Winter. Here are my questions:
1) Looking at picture(s) do you think the satellite signal to the dish is being blocked by the roof next door?
2) Does the latitude of 42.7° motorized on inverted dish, as in my case 29° + 4.55 = 33.5° look at the satellite at 41.4° original elevation without motor for 72°W or does it see the sat @ 72°W at 33.5° motorized modified dish elevation?
3) I don’t know if the roof ofthe house next door is my problem, or my setting on both the Motor Latitude and Dish elevation is the problem?
4) What are the active Transponders on 72°W?
Short of placing this install on my front lawn and hope the neighborhood kids don’t get to it, I don’t want to climb any higher to install this dish and motor. Any ideas?
