In general the setting on the positioner for your location should be in the ball park of what it should be. If you are way off from this, then your "arc" will be off.
The bottom line is the elevation of the dish for each satellite (see below). Then the arc is adjusted with the positioner elevation "hand in hand" with the dish elevation adjustment. To change the arc, adjust one setting down and the other up, or the other way around. I make these adjustments when on a south pointing satellite. Then move dish back and forth the check the arc after adjusting.
Now different dishes have different "offsets" (value to plug into the below calculator). I have never seen this value included with the instructions included with any dish I have purchased. I have had to go to the manufacturer's web site and find the specifications for the dish! The offset amount of the dish can be 15 degrees, 18 degrees, 22 degrees, etc. and of course 0 for a prime focus dish.
For accurate aiming, you can use an "inclinometer" on the back of the dish along with a dish pointing calculator. And a handheld GPS (set to real heading, not magnetic) for direction the dish is pointing.
Here is a dish pointing calculator...
http://www.satellite-calculations.com/Satellite/lookangles.htm
