Digi question for you ..This mean this ch can transmit at HD on any moment?
It so will be the first one in Puerto Rico.![]()
I'm not sure what you are asking... any TP can transmit HD at any moment.
This beam covers parts of LA, MS, and AL.
It make sense what you said however that channel is part of the local channels available only in Puerto Rico ,really odd.
I found this info over the net
WSJU Channel 30 Delivers Programming to Cable Network Over T1 Line Using Envivio MPEG-4 Media Transport Solution
Wrong. Tpns doesn't care!But transponders evidently have to transmit either All HD or All SD...
I noticed since SetantaSports is now uplinked will we also get the 2nd channel of the extra matches like on D*, I think it's still called Setanta Extra.
WJSU----WSJU
I was under the impression that a transponder has to be set to be either 8psk (HD) or Qpsk (SD) ??Wrong. Tpns doesn't care!
It is done a few times a day by Digiblur, however the godfather of uplink's JohnH is constantly watching the stream and alerts me or Digiblur of changes.How often is the Uplink Activity checked by those who are dedicated enough to do so for us ?
Perhaps you are referring to FOX Sports Espanol. I don't see any "Setanta Extra" on D*
It is done a few times a day by Digiblur, however the godfather of uplink's JohnH is constantly watching the stream and alerts me or Digiblur of changes.(Thanks JohnH!)
In addition we are looking at doing real time live monitoring of the stream which can produce real time updates as they happen. We have talked to a few folks who may be able to write the PHP / MySQL code necessary to do this.![]()
Hands-on is better. There are occasionally some non-corrected errors on download and how to automatically handle Rain-fade is another problem. Running an update every hour would be a waste of resources. I generate an archive every time I run a scan. The oldest I have now is June 3, 2004 which has survived 3 computers.![]()
I've been a bit curious of this myself.How is it "monitored"?
Not that I want to, just seems pretty cool you can see uplink activity, and since ive never asked.![]()
