Four more questions:Yes, RG59 will work for all Joeys, including Joey 4's.
It sounds like you are mixing up the 4K Joey and the Joey 4. The 4K Joey has the same UI as the H3. The Joey 4 does Android apps. I have a 4K Joey and a Joey 3 in my setup. They are both pretty speedy. The 4K Joey has little to none 4K so I would go with the Joey 3 if suits your purposes.Four more questions:
1. Is the 4k (wired) faster than the J3 (in the guide, menus, etc.)? I don't care about 4k video, just speed for better ease of use.
2. Does the 4k have the same UI as the H3, or is it like the H+?
3. Does the 4k run Android apps like the H+?
4. Are there any known problems using a 4k with a H3 without the H+?
I HATE that menu and other than H+ and Joey 4's you CAN turn that off in Settings\Appearance\Menu\Classic2. The UI is the "tiles" one like the H+, but the standalone H3 has gone to that style now anyway.
Yes, I was confusing them a bit. And the wording of my questions was a little vague. Let me try asking less obtusely.It sounds like you are mixing up the 4K Joey and the Joey 4. The 4K Joey has the same UI as the H3. The Joey 4 does Android apps. I have a 4K Joey and a Joey 3 in my setup. They are both pretty speedy. The 4K Joey has little to none 4K so I would go with the Joey 3 if suits your purposes.
The J3 and 4K Joeys UI look just like the H3. Even if you have no interest in the 4K properties the 4K Joey would probably fit your bill.Yes, I was confusing them a bit. And the wording of my questions was a little vague. Let me try asking less obtusely.
I have a H3 with the Appearance settings set to "classic" for both the Home Screen and Theme preferences. I have no interest in 4k video or Android apps, so those don't play a part in the decision and can be ignored.
Instead, between a J3, J4, and 4kJ, which one will be the fastest and maintain the same UI look-n-feel as how I have my H3 configured.
