Thanks Bobby. Does the 1000.2 come with both the older LNBS and the hybrid LNBs?The internationals are rapidly moving to streaming only. There should not be a use for that location any longer. I'd go with the 500 and move your 110 119 lnb over to it and call it a day. That would still incorporate your 42 switch which is a requirement for you 2 H3s.
The 1000.2 can accommodate either but in your case you have to use the DPP+ because you need the 42 switch to add in the hybrid part for your 2 H3s. The Hybrid lnb doesn't appear to play nice with the 42 switch.Thanks Bobby. Does the 1000.2 come with both the older LNBS and the hybrid LNBs?
I am starting to research the 1000.2 and .4 dish. I sure like the 1000.4 better because it is bigger. Do they still make the 1000.4 Western Arc setup?The 1000.2 can accommodate either but in your case you have to use the DPP+ because you need the 42 switch to add in the hybrid part for your 2 H3s. The Hybrid lnb doesn't appear to play nice with the 42 switch.
I have no idea, HipKat is better served to answer that. I will say bigger is not always the answer. If you are, or were, served well with a Dish 500 nothing has changed and you would still be served well by it. Perhaps Scott, who has physically tried all of these dishes, could pop in here.I am starting to research the 1000.2 and .4 dish. I sure like the 1000.4 better because it is bigger. Do they still make the 1000.4 Western Arc setup?
Thanks Bobby. Help help HipKat and Scott GreczkowskiI have no idea, HipCat is better served to answer that. I will say bigger is not always the answer. If you are,, or were, served well with a Dish 500 nothing has changed and you would still be served well by it. Perhaps Scott, who has physically tried all of these dishes, could pop in here.
500 would serve probably the best as it's designed with no compromise like the 1000(.2) to also take in 129. Also a bit more compact with less load on mounting. It's a very old dish at this point, but if we're back to just 110/119, and it uses the DPP Twin, well...
Thanks. I can't wait to hear from HipKat. He works in Illinois and I live in Illinois. He can lead me on what Dish will do.I think they relaunched the 500 with a new LNB since only 119/110 are needed any more. I'd like to swap out my 1000.2 but can't find one.
Once they stopped using 129, I took the 1000.2 out of my travel trailer and went back to using a D500.500 would serve probably the best ....
The Dish 300 was a single focus dish and was the only one they made with no compromise because it has only one focal point. The Dish 500 has dual foci and thus the dish while being parabolic in the top to bottom aspect is splayed open slightly in the horizonal aspect and had to have a larger surface area to partially compensate for being out of focus horizonally.500 would serve probably the best as it's designed with no compromise like the 1000(.2) to also take in 129. Also a bit more compact with less load on mounting. It's a very old dish at this point, but if we're back to just 110/119, and it uses the DPP Twin, well...
No. Again, the third "eye" is for the defunct 129. You CAN just keep your 500+. It'll just not show anything for the 118 and 129, but still work fine for the 110 and 119I am starting to research the 1000.2 and .4 dish. I sure like the 1000.4 better because it is bigger. Do they still make the 1000.4 Western Arc setup?
