First SuperDISH installed
According to various sites (lyngsat & dishchannelchart.com), Milwaukee is on TP19
Each channel goes on a specific TP (transponder) and you cant change it
I am receiving word from a few retailers that they have been shipped SuperDISH units from Dish Network, many of them will do their first installs today!
I have had a secret for the last month or so which because of the fact the SuperDISH has been released to the public I can disclose today. The folks at Dish Network were kind enough to send me a SuperDISH last month.
The SuperDISH I received was a Type II Dish and was not a beta unit, this was an honest to goodness retail packed SuperDISH.
The huge 45 lb box arrived at my house and look like this
Opening the box you could see the SuperDISH reflector on the top of the box as shown below
Everything was packed nicely and safely for ground transportation, below is the box the LNB came in, this LNB was only a few days old when I received my unit.
This is what the LNB looked like out of the box, notice that this is a heavy duty LNB, this LNB assembly is no cheep $30 WalMart LNB replacement kit.
Also in the box was a SW 34 switch, a mounting ARM (mast), LNB support Arm, the Mounting Bracket, 3 pieces which makes up the LNB shroud, misc parts like nuts and bolts and cable clips.
Assembling the SuperDISH was surprisingly easy! I had the Dish together in less then 10 minutes! When I put together my DirecTV Para Todos Dish it took me over 2 hours to assemble that bad boy.
I decided for this Dish I would not replace my old Dish but put this dish on the side of the other one. This unit would be pole mounted.
I went down to Home Depot and purchased a galvanized fence post (Perfect 2 3/8"!) this was only $7.49 for a 7 foot pole. I also purchase a bag of no mix quick set concrete.
surprisingly Digging the 3 1/2 foot hole in the ground was not as hard as I thought it was going to be, took me only 10 to 15 minutes to get all all done.
Then I put the pole in the ground and used my level to make sure everything was ok. Then by using the directions on the bag of concrete I filled up the hole half way with water, then I poured the concrete in, as it was setting I was checking the pole with a level making sure the pole was perfectly plumb. 15 minutes later the concrete was hard and holding the pole securely. I filled in the rest of the hole with the dirt that originally came out of the hole.
I gave the concrete an hour to dry some more and went and had lunch.
When I got back from lunch I went and checked the pole, still perfectly level. A friend of mine who is a retailer came over with his satellite meters. He wanted to watch me put the Dish on the pole and see how hard is was to align the SuperDISH.
I went in the house and got the assembled Dish, I then set the skew on the Dish per the manual. After that was locked down, I set the elevation again per the manual. I then placed the Dish on the pole. My friend hooked up his Bird dog meter to the 119 LNB so this way we could easily align the Dish. To his surprise the way I put the Dish on the pole we were seeing the 119 perfectly with no adjustments!
He then moved his meter to 110 again we were dead on with a very high signal.
He then moved his meter to 105, where we showed no signal. He had a feeling it was his meter and took a small spectrum analyser out of his truck, we hooked it up to 105 and BINGO we could see the transponders on the 105 satellite! We have somehow hit all 3 satellites dead on by dumb luck! We were so happy and excited, the neighbors must have wondered what was going on when they saw two guys dancing in the front yard. :)
We locked down the Dish and ran the cables to the SW34 which I mounted next to my SW64 switch on my house (as shown below)
Earlier in the day I unhooked my 6000 and my 721 from the SW 64, I purchased a Dishpro adapter for my 6000 and had it hooked up and ready to go, so all I needed to do was move the unhooked cables to the sw34 switch.
I hooked the cables up and went into the house to the Dish 6000 and Dish a Switch Test. This switch test was a LONG process it took over 10 minutes to complete, but when it was done there on my screen was 119, 110 and 105 all verified.
I quickly grabbed the remote to turn on HBO-HD... It wasn't there...
I tried Showtime HD... Nope that was gone as well
Not even the HD demo channel was available...
We were both disappointed there was nothing on the SuperDISH to watch. Just as my friend was about to leave to do another install I noticed a new channel which I never have seen before, and that was channel 7000 which told me that I had my Dish pointed at 105 Degrees W.L., when we say this we again did another happy dance.
My friend then left.
I went outside to put the LNB shroud on the Dish, this was probably the most complicated portion of the install. The 3 pieces snapped together nicely but I feel it was designed backwards, instead of screwing down into a nut you had to go from the bottom up. It took me a good hour to to get that shroud properly installed.
But once it was done, I was happy. I believe i watched Channel 7000 and listened to the music for a good part of the night. :D
Here is a photo of my completed SuperDISH.
Here is a close up of the LNB Shroud from the front, note that the HDTV logo on the front is painted on. My wife wishes that logo was an optional sticker, she does not want to advertise to the neighborhood that we have expensive electronics in the house.
And a view of the LNB Shroud from behind.
Here is my SuperDISH next to my DirecTV Para Todos Dish (and I thought the DirecTV 24 inch Dish was big)
And finally here is my satellite layout. Notice I have DirecTV, Dish Network and ExpressVu all on one Dish. :) (I do not subscribe to DirecTV or ExpressVU anymore though)
So far having a SuperDISH has not been super as I have lost a few of the HD Channels I was getting off of 61.5. The only channel I have been able to get has been 7000. Now that the SuperDISH is rolling out for those that need them for locals they will enable the HD channels as well as I am sure there are a few who will be getting locals who are also SuperDISH owners.
My signal strengths are not bad at all, they are higher in fact then the signal levels shown on a SuperDISH training video I recently saw. Rain fade has NOT been a problem on 105 at all, and thats a good thing!
My thanks again to the folks from Dish Network for making this possible, and for allowing me to do my own install.
While I may say it was easy for me to install it was because I had professional tools at my disposal. Most users will not have a Bird Dog meter and Spectrum analyser to properly peek things.
My advice if you want a SuperDISH is to take advantage of the free install deal.
Thanks for visiting SatelliteGuys.US Today!
Why is this superdish wider than the newer superdish
A little larger.
I'd be interested if this allows them to prevent any of the dropouts that occur in sub-optimal weather. And if it is a free install
The superdish that came out after the one in the picture. Newer superdish is a less wide dish
What does the new Superdish get you if you have the normal dish?
Better signal strength?
My supposition?
Is Dish getting ready to provide DirectTV access as well???
The wider dish can probably easily pick up the DTV sats as well.
Who wants to put money on it?
My supposition?
One more time, there is no new Superdish. Comments toward a new Superdish were from 21 years ago. If anything we are more apt to see 500 dishes come back because each arc only has 2 coverage satellite location.
Hopper3 deleting recordings by itself
External hard drive
