PQ is better with the J4 and WJ4. Remote controls also sluggish like the H+. Press a button to do something and sometimes it is up to about 2 seconds for response.Thanks. Is the picture quality better on the the J4 and WJ4 as well?
Very good question!Scott Greczkowski what do you think?
Well, that sucks. Let us know if it's still sluggish when you pair with your 2nd H3.PQ is better with the J4 and WJ4. Remote controls also sluggish like the H+. Press a button to do something and sometimes it is up to about 2 seconds for response.
Well Bobby what a headache. Last nite on one of my J4s I tried to link to my 2nd H3. Joey quit working, got the screen that says Joey not authorized call DISH. Pulled the cord reset several times, same thing. So I pulled the cord on 2nd H3 and disconnected the back coax. Tried another hard reset on the J4 and same thing. After the hard resets the Joey gets to the app screen. When I click back button or settings button it immediately goes to the Joey not authorized screen. So called DISH this morning. They tried everything to authorize that there J4. Nothing worked. So got a DISH tech coming tomorrow.Just for grins you might try to connect one of your new Joey 4s to the Hopper 3 without the Hopper+. I know the Joey 4 will work without a Hopper+ so it just might work. You are not going to break anything. If it doesn't work simply go back to the original configuration.
Well, that answered that question. Now we might know why 2 Hopper 3s are not allowed. Thanks for being our guinea pig Charles...Well Bobby what a headache. Last nite on one of my J4s I tried to link to my 2nd H3. Joey quit working, got the screen that says Joey not authorized call DISH. Pulled the cord reset several times, same thing. So I pulled the cord on 2nd H3 and disconnected the back coax. Tried another hard reset on the J4 and same thing. After the hard resets the Joey gets to the app screen. When I click back button or settings button it immediately goes to the Joey not authorized screen. So called DISH this morning. They tried everything to authorize that there J4. Nothing worked. So got a DISH tech coming tomorrow.
You are welcome. LOL. Yep you are probably right. I must of screwed up the firmware in the Joey I guess.Well, that answered that question. Now we might know why 2 Hopper 3s are not allowed. Thanks for being our guinea pig Charles...![]()
If the Joey will still work on the First Hopper 3, then maybe. If Joey doesn't even work now on the First Hopper 3 then it could be one of those glitches.Well, that answered that question. Now we might know why 2 Hopper 3s are not allowed. Thanks for being our guinea pig Charles...![]()
Already tried that Bobby.You might try this, Charles, Unplug the Joey 4 with the issue and then the standalone Hopper. Plug the Joey 4 back in and let it sit for a bit. It might find the Hopper with the H+ and load the proper software. If that works, leave it alone and never try to load to the standalone Hopper again.
I agree. 40.0 remote the best!As you will notice the 40.0 remote does not work well with it. They want you to use the DISH Vice Remote with it and ONLY the Dish voice remote.
My wife HATES the Dish 54 remotes but its the only way she has full access to her recorded shows.
Hopper+ installed today along with two J4s and two WJ4s.
Maybe sometime. To be honest with you we don't warch hardly anything 4K HDR unless thru the Fire Stick. 1080P thru the Hopper is good enough for us.So when are you posting a video? Including HDR artifacts.
Please?![]()
I can confirm without the Hopper+, the WirelessJoey 4 can see both Hopper 3's. Now I never tested it with the Hopper+ since it was disconnected on Day 1 of install and before activating 2nd Hopper 3. So, I have not gotten to it to go back and test to see if the Wireless Joey 4 can see both Hopper 3's when Hopper + is installed. I will try that when I can a chance as I assume Charles can answer that as well since he had the Hopper + installed and whether or not the Joeys could see the 2nd Hopper 3. My Hopper 3's are on Solo Hybrid Hubs and then tied together with a coax. I don't have them on the Duo Hybrid HubI have two Hopper3 receivers and a Joey3 client. My setup is wired like charlesrshell.
Currently both Hopper3 receivers can access programs on the other Hopper3 and my Joey 3 can be linked to either Hopper3. Plus my Joey3 can access programs on either Hopper3 receiver.
If I understand the posts from charlesrshell:
1) The new Hopper+ can not access programs on his other Hopper3.
2) His second Hopper3 can not access programs on the Hopper+
3) Trying to link the Joey4 to the Hopper3 caused the Joey4 to stop working.
Based on those facts I would not want a Hopper+. But what I would like to know is if a Joey4 would be able to access programs on two Hopper3 receivers. If that would work I would consider installing a Joey4 in the basement so I would have 4K HDR capabilities.
Whenever I remove the Hopper+ and go back to two Hopper 3s mode I will let you know if the Joey 4 models can access programs on both Hopper 3s.I have two Hopper3 receivers and a Joey3 client. My setup is wired like charlesrshell.
What kind of video do you want to see of the Android platform?BTW, there is a year old Hopper + video on YT. But it's 9/10ths of worthless.
With Hopper+ attached to primary H3 I can see the 2nd Hopper 3 on a Joey 4. But when I select it and select a recording to watch I get a window that says playback stopped. So that is a no go. Same thing happens with the H3+. I can see the 2nd H3 drop down menu but the recordings on the 2nd H3 do not work.I can confirm without the Hopper+, the WirelessJoey 4 can see both Hopper 3's. Now I never tested it with the Hopper+ since it was disconnected on Day 1 of install and before activating 2nd Hopper 3. So, I have not gotten to it to go back and test to see if the Wireless Joey 4 can see both Hopper 3's when Hopper + is installed. I will try that when I can a chance as I assume Charles can answer that as well since he had the Hopper + installed and whether or not the Joeys could see the 2nd Hopper 3. My Hopper 3's are on Solo Hybrid Hubs and then tied together with a coax. I don't have them on the Duo Hybrid Hub
