Thank you very much for a fast answer.
Really apreciated. Dish is mesh. I hope someone here has already done it and could tell me about the do's and dont's.
You're welcome! I agree with
John. If you are able to add some form of adjustment plate to your dish pole then do so. It will make things easier down the line. If you can't then just make absolutely sure the pole is plumb. In either case if you are mixing quikrete yourself by the bag then here is a concrete calculator with both flat work and cylinder calculation. Results are in cubic yards.
Concrete cubic yard calculator for cylinders, sono-tubes, walls, sidewalks, slabs and floors
www.everything-about-concrete.com
The yield of a bag of quikrete is measured in cubic feet so use this to convert:
40lb bag = .3 cubic feet = .01111 cubic yards
60lb bag -.45 cubic feet = .01666 cubic yards
80lb bag = .6 cubic feet = .02222 cubic yards
Example 1: If you poured a cylinder for a pole and went to 4 feet depth and your hole was 2 feet across then you would need .47 cubic yards (from the calculator). The pole itself takes up some of that space so I always use the extra to fill up the inside of the pole to make it stronger. That would equate to:
(42) 40lb bags or (28) 60lb bags or (21) 80lb bags
Example 2: If your poured a square base with rods to mount an adjustable plate. At four feet depth and two feet across you would need .59 cubic yards.
(53) 40lb bags or (35) 60lb bags or (27) 80 lb bags
Of course how much you will need in your situation still needs to be determined. If mixing it yourself I hope you have a machine.
