Finally got motor installed. Need some help..
comfortably_numb
20,860
32,671
Kansas City
Where do I find the cooridinates required on this screen in the Amiko hd.265?
Not on that screen. Go to satellite setup, down to motor and right or left arrow over to select USALS then hit the OK button and enter your coordinates.
Reactions: comfortably_numb
Yes.
If I want to run 2 receivers off my splitter, do I need to use a DC-pass thru for one of them? Will having LNB power turned on for both receivers fry my LNB? I only want to use the Amiko to drive my motor.
I don't think it would fry the LNBF. But if one receiver outputs 13V and the other output 18V, what would happen to the one sending 13V but being also fed 18V. That could potentially smoke that receiver. Unless the splitter has diodes to avoid feedback.
Instead I would use a splitter that carries DC only on one port, us that port for the receiver that drives the motor and LNBF, and connect the other receiver to the non-DC port, with the understanding that it would be unable to control the polarity and only receive the polarity that the first receiver has selected
Of course you would be much better off with a dual LNBF and 2 cables
"All ports power pass" splitters can be power pass one way (with diodes), or power pass both ways (no diodes).
Alas, that is not always indicated (or not clearly indicated) on the splitter. So I always measure, with a multimeter.
Or I test them by connecting the splitter in the reverse, 'input-out' so to say, and check if there is reception again (NB if the LNB has multiple outputs, these other outputs must NOT be connected to power, while testing the power-through of the splitter!).
All ports power pass one way splitters are good for two receivers, serving one LNB. Alternative would be a smart priority switch (master/slave switch), if you don't want to watch at both receivers simultanuously.
All ports power pass both ways splitters are ideal for having a parallel setup with diseqc devices on one receiver, e.g. having a motor (or VBox) and a diseqc switch at parallel lines.
Greetz,
A33
Edit: From the photo: it looks like comfortably_numb already has a DC-blocker, to implement the suggestion from Brct203 : "Instead I would use a splitter that carries DC only on one port".
KE4EST this question is primarily for you, as our resident Amiko expert :)
it seems like my receiver will randomly forget the motor position for a satellite here and there. It doesn't happen on all of them, but I have had to delete 91 and 105 and re-add them several times. Is this a known issue?
USALS?
What do you mean it forgets? Do you go to satellite setup and it no longer shows USALS as motor?
USALS just sends a command to the motor via a calculation based on your lat and long you entered. Other than that does not really store anything. If DiSEqC that is all stored in your motor.
No known issues with motor controls. Usually when I see this, the customer has bad coax, connector, switch or too many switches in line and the DiSQeC commands are not getting through at all or they are very attenuated.
OK I think I figured it out, I had tried to bump and nudge the motor in the USALS screen for a couple of those satellites and I think it screwed up the positioning. Once I did a factory reset on the receiver all seems to work correctly
Reactions: FTA4PA
Ok, just when I thought I had all this figured out... for some reason when I select certain sats, the motor tracks to 95. I have no idea why. It does this about 50% of the time. I'll select, say 105, and the motor goes to 95. What the heck??!
  • Sad
Reactions: FTA4PA
Hey there, as one speaking from USALS headaches, i don't know if this post will help you, but ill post some problems i have had with various STB's.
My old Non Linux STB from Europe , i could set USALS or Diseqc but if i used the store sat position button on my remote, it would swap between USALS/Diseqc and if i had diseqc stored in the USALS, it would use that instead. - Make sure your receiver considers the Sats to use USALS and not Diseqc. Diseqc will work, but then who knows where the USALS will land up.
With my Enigma2 STB, Each satellite uses the same LNB but, i can set whether it uses Diseqc or USALS, and the configuration can be quite tedious, and you have to check/double check everything 4 times.
I also had a problem in the past where my Diseqc/USALS would get lost if i configured the channels between the STB channel editor and the back end software channel editor.
And as a final note, i have a STB that supports 4 separate coax lines. I use one dedicated to USALS. As KE4EST mentioned, diseqc switches can cause headaches....
I hope you figure it out.....
What Satellite?
Lyngsat Updates
