Thanks.New come in electrostatic bags with the protective plastic on the front panel doors. Refurbs come in shrinkwrap
I worked for a different one for a while there and they had both.I hate to tell you but RSP's only have what Dish sends them.
If you get a moment need to figure out whats needed next. thanksHello, dvrexpander. The File System Check process is usually not an indicator of an issue on its own, as it occurs after a reset of the Hopper. Since the check and the self-resets, have you manually rebooted the Hopper by unplugging it? If you have and it continues to reset on its own or gives the File System Check message again, it could be a warning of a power issue to the Hopper.
We get both also, but the policy is first on (the van), first offI worked for a different one for a while there and they had both.
They purposely pushed us to use the refurbs first since they were cheaper for them.
I'll request a new one regardless.
What is your opinion on the refurb vs new?We get both also, but the policy is first on (the van), first off
I searched a little but couldn't find an exact reference to this issue.
I don't watch it much anymore but noticed the other night the Hopper 3 just reset itself, went thru a file system check all passed and booted back up.
Last two nights roughly same time frames 8pm-9pmish it reset once each night around those times but didn't do a file check.
Is this thing failing? Can someone with DIRT contact me if so about having it replaced before recordings get lost and I can't transfer if it fails?
I've seen enough to know that Dish's reurb process is crap. Hoppers with Timers still set on the Timers Menu, overheating, hard drives failing shortly after installation are more common than you'd thinkWhat is your opinion on the refurb vs new?
Good to know, I'll request new or_____!I've seen enough to know that Dish's reurb process is crap. Hoppers with Timers still set on the Timers Menu, overheating, hard drives failing shortly after installation are more common than you'd think
Lol I used to install these things...I know all to well not to get a refurb unit from them.Good to know, I'll request new or_____!
I have a tech coming out, if they want to replace my H3 I'm going to demand new, Hope it goes well!Lol I used to install these things...I know all to well not to get a refurb unit from them.
You can demand all you want. You will get what they have....I have a tech coming out, if they want to replace my H3 I'm going to demand new, Hope it goes well!
I'll cancel before I accept a refurbishment, I'm not gonna play games with Dish anymore.You can demand all you want. You will get what they have....
Then be prepared to back it up. If the tech doesn't have a new one all he can do is a refurb. They really don't care if you leave or not.I'll cancel before I accept a refurbishment, I'm not gonna play games with Dish anymore.
I'm close to that decision anyway. I spoke with somebody in Tech, told them if I need an H3 replacement that it has to be New or I cancel.
So, the ball is the DISH-TV court!!!
Yep, I know. Don't worry about what I back up or not, Bobby.Then be prepared to back it up. If the tech doesn't have a new one all he can do is a refurb. They really don't care if you leave or not.
I was about to say the same thing, almost word for wordYou can demand all you want. You will get what they have....
That's not how it works. If you need to transfer or backup recordings, we'll leave the old receiver and call Dish to send you a return kitFor the most part RSP's will get the notification of needing a new when requested. The one I worked for got it from many customers and they had a nice new pallet of receivers ready to go for those particular. I think for the most part just having an H3 swapped should be as easy as swapping from it being mailed out. After all I know for me I've gotta back up a bunch of saved movies/shows etc so that will take some time anyway vs have a tech come stand there and watch for peanuts in pay.
