Repurposing My Orby Boat Anchor Dish
Cosmo Blatz
581
464
S.E. WI and Central NV
I realize I can us the Orby LNB. My question is, if I move the dish from its current position on Eutelsat 116.8 W over to 87 W will the skew automatically be correct when I'm on 87W. Seems the design of the ORBY mount and dish should give the correct skew on any satellite.
Am I correct on this? Or do I have to modify the Orby LNB mount so the LNB can be manually rotated to the correct skew for 87W?
If you are interested in adding a dual LNB to the Orby dish - I believe it is the same as the 60cm Shaw Direct Channel Master dish, which originally came with a dual Ku for 4 degree satellites 107 and 111. They got upgraded to an xKu/Ku a few years ago and a lot of the original dual Ku are still floating around looking for new projects. 60cm is a bit small for most FTA but for music on 103 and stuff on 99, it might be a thing. Same with 87 and 91.
I don't know if you or someone else can answer this for me since you're talking about Orby. I have a DVR that still functions as it did prior to Oby shutting down If I purchase another DVR from some existing stock, will it work with the OTA channels as the one I currently have, or would it require some type of activation before it would work?
I believe only activated units will function. :( This thread will bring you up to speed. Usage after demise: Hacking receiver's and DVR's firmware for something else?
You will indeed need to adjust the skew on the Orby dish when re-aiming to another satellite. And -- yes -- that is accomplished by rotating the entire dish after loosening the nuts surrounding the skew axis. Dishpointer.com will provide the skew setting (as well as azimuth and elevations settings) once you zero-in on your location and select the satellite you want to point to.
I have an Orby dish and went through all of this after the Orby company demise and I went FTA with it. pointing it to 103W. I got an Amiko HD265 from Michael and connected that to my Orby dish.
Richard
Reactions: k.r.
Hello Again. Got my dish going after a long break.
C band
