Needing to know what External hard drive will work with Hopper 3 & wallys. Do any of the usb powered models work?
The constant read/write on the SSD will wear it out much faster than it would a spinning drive.I have a 1TB EHD on a Wally in the RV for DVR function and no moving parts. It is a 2.5" form factor SanDisk SSD running from USB power.
I have a 2TB EHD on a Hopper 3. It is a 3.5" form factor Iomega drive with external power supply.
Can we please give the "SSD will wear out" thing a little rest? Especially on the same day that someone posted about a clicking sound coming from their H3?The constant read/write on the SSD will wear it out much faster than it would a spinning drive.
That is coming from where Dish hid the self-destruct bomb.Especially on the same day that someone posted about a clicking sound coming from their H3?
I have tried a Western Digital My Passport 1TB USB 3.0 drive with a Wally. It is a USB-powered drive, and it has worked flawlessly for at least a couple of years. (A Wally would put the most strain on such a drive, since all DVR functionality, including the Live TV buffer, is constantly going through that drive before being displayed on the TV screen.) I don't have a Hopper 3, but this exact same drive has been used many times for transferring recordings to and from Hopper Duo and ViP DVR's on the same account. (After reformatting the drive each time of course, since the formatting used for that is different from the formatting for a Wally.) I have not had any problems using it with those models, either.But it does point out that the USB-powered drives work with a Wally. I haven't tried it with a Hopper 3...
In order to clear out the pipeline of H3 units by incenting the masses to purchase their own "new" H3, prior to introducing the H4 "Jupiter-Saturn and Uranus Conjunction" with 256 tuners.That is coming from where Dish hid the self-destruct bomb.![]()
I'm not sure that the Intel 256 GB SATA SSD that died at work "wore out" or rolled over the Power-on Timer register, but the end result was the same: we had a 2.5" SATA brick. Unusable for all practical purposes.Can we please give the "SSD will wear out" thing a little rest?
That's interesting. And I think many of us have had a 2.5" IDE, EIDE, and even SATA spinning hard drive brick. But we should probably hark back to the poster's question...EHDs that will work with H3s and Wallys.the end result was the same: we had a 2.5" SATA brick.
Exactly. I had an SSD sitting around that I had upgraded from, and I repurposed it to use as an EHD for a Wally. Maybe it'll fail. Maybe it'll just sit there, unaffected by temperature and vibration and be a decent solution for a Wally in an RV. But I appreciate the "expensive SSD instead of a real HD" thing.You can easily use an SSD
Don't forget the 7-day guide, which is also stored on the external hard drive. Those guide downloads also occur when the Wally is turned off. However the Wally, just like the ViP211 series, does have a two-day guide without any hard drive attached. So, you would think that maybe it is only storing the remaining five days of guide data on the hard drive. However, whenever the hard drive is unhooked, the Wally needs to take a fresh guide download again. So, I would guess that the entire 7-day guide is being stored on the external hard drive, and the internal storage space reserved for the two-day guide data is only used when there is no hard drive to use for storing the guide data.I do not have a Wally, but my understanding is the Wally works like the ViP 211 before, the EHD is used for long-term archival as well as a 60 minute trick play buffer. The archival function is a write once, read many situation which will not tax the SSD's flash memory cells, but the replay buffer is being written to constantly, even with the Wally turned off (again, assuming behavior that mirrors the ViP 211).
Can the Hopper 3 (H3) really use all the capacity of a 7TB drive since I thought 2TB was the largest it would allow usable per drive?
The trick would be to actually find a 7TB drive, since the standard sizes are 6TB and 8TB. People have had mixed results. Trying a single 8TB drive, it was not recognized at all. Trying a 6TB drive, one member was successfully able to add a 2TB drive, for a total of 8TB. However, another member with a 6TB drive was not able to get the Hopper 3 to recognize a 1.5 TB drive. In any event, at least 6TB will actually work. It is when you try to approach or exceed the 7TB "limit" where things start to get weird.Can the Hopper 3 (H3) really use all the capacity of a 7TB drive since I thought 2TB was the largest it would allow usable per drive?
Exactly. When I walk by the Wally in the bedroom I can hear the drive spinning and see the led blinking when it's "turned off" (it never really is off, only in standby). Same for the one in the living room. In that situ an SSD would not be a good ideaI do not have a Wally, but my understanding is the Wally works like the ViP 211 before, the EHD is used for long-term archival as well as a 60 minute trick play buffer. The archival function is a write once, read many situation which will not tax the SSD's flash memory cells, but the replay buffer is being written to constantly, even with the Wally turned off (again, assuming behavior that mirrors the ViP 211).
Yup, and I can report that the 6+2 combination still works in U939. Probably shouldn't talk too loud or someone at Dish may just "fix" it!The trick would be to actually find a 7TB drive, since the standard sizes are 6TB and 8TB. People have had mixed results. Trying a single 8TB drive, it was not recognized at all. Trying a 6TB drive, one member was successfully able to add a 2TB drive, for a total of 8TB. However, another member with a 6TB drive was not able to get the Hopper 3 to recognize a 1.5 TB drive. In any event, at least 6TB will actually work. It is when you try to approach or exceed the 7TB "limit" where things start to get weird.
