Connect an HDMI cable from your TVs HDMI Input to the TV Out (white one) on the back of the AVR. Connect another HDMI cable from the HR24s HDMI out to any one of the HDMI Ins on the back of the AVR, it doesn't have to be the SAT/CATV In if you don't want it to be. Tune to the appropriate HDMI input on the TV and select the source on the receiver and you should be all set.
If you have any other HDMI sources like a gaming console or blu ray player, connect them to the A/V Receiver as well.
Leave the TV on the HDMI In and let the A/V Receiver act as an A/V switch to toggle between sources.
The receiver supports Audio Return Channel (ARC), so any audio that comes from the TV or one of the built in apps will be processed by the receiver.
Okay, I have a silver braided HDMI cable plugged in the Vizio HDMI #1(ARC). That is the ONLY cable coming from the back of the TV. That silver coax goes into the A/V Receiver TV OUT(ARC). I have an HDMI cable coming from the Directv box, going into the SAT/CATV IN.
Sound works fine. No picture.
ON EDIT: When I press INPUT on TV remote, all 3 HDMI settings indicate NO SIGNAL...
